Special IDI tools - Ford Truck Enthusiasts Forums
Special IDI tools
Old 02-14-2017, 09:16 PM
we287gn we287gn is offline
we287gn is starting off with a positive reputation.
Special IDI tools
I was looking for a compression gauge that would read high enough ,came across this one from Jegs... Thinking about grabbing it, wish it was a 500 psi scale , but I'm pretty sure it has the proper adapter ..M10 X1.0 correct?
JEGS Performance Products W89731: Diesel Compression Tester Push-Button Side Release Valve | JEGS
Also going to grab the ferret timing tool... Hopefully they are readily available ..
Have a 87 6.9 going to test out and determine wether I should keep it for a rainy day or not,so figured comp test is first place to start, then coolant pressure???
Any other special tools an IDI guy should have???
Old 02-14-2017, 09:48 PM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
Quote:
Might want to order that ferret adapter asap. I ordered mine a few months ago, and it took over a month to arrive. Probably not high selling item for them, so they don't make it a priority. Also, make sure you order the right size piezo clamp.
Maybe something to test your injector pop pressure, since you are willing to spend the cash.
Old 02-15-2017, 04:52 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Only special tool you "need" is a bent 9/16" wrench for removing the IP. I would say compression tester and ferret adapter are more wants. I do however have the cheap harbor freight compression kit, w/ 1000psi gauge, and a ferret adapter. When i ordered mine it showed up within a week.
Old 02-16-2017, 06:17 PM
Thanks for the reply guys.
Everyone getting them from this "tool discounter" place? Comes with a 1/4"(6.35mm) adapter? Going to go measure the line now..
In regards to the 9/16" , think I have an extra cheapy wrench around to make that happen..
I'll have to research the pop test thing...thanks for the heads up..
Old 02-16-2017, 07:01 PM
jayro88 jayro88 is offline
jayro88 is gaining momentum as a positive member of FTE.
There is also a special IP wrench that can be used to rotate it when setting the timing. Most IP's have a nub on top that a box end wrench can fit on, but not all of them. Plus the wrench spreads the twisting load out some....I have heard of the nub on top breaking off when using the box end wrench on rare occasions.
Old 02-16-2017, 07:09 PM
cadunkle's Avatar
cadunkle cadunkle is offline
cadunkle is gaining momentum as a positive member of FTE.
As far as I know you're only looking at some tool to set the timing, glow plug compression tester fitting, and a freeze plugs installation tool.
302 carb swap to 351w stroker carb momutt Engine Swaps 4 12-19-2015 01:38 PM
Jeg's C6 stall converter hivoltj 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-30-2015 05:13 PM
Need Help; Switching From Clutch Fan To Flex Fan ovalhead72 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 08-01-2015 07:55 AM
New intake for my 352? Flip4ford 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-23-2013 11:45 AM
351M valve spring question. MikePacey 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-01-2013 11:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
