Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Lightning 5.4 and non lightning 5.4
Old 02-14-2017, 08:44 PM
wa-sleeper's Avatar
wa-sleeper
wa-sleeper is offline
Are they the same trans bolt pattern? I'm wanting to swap out my 4.6 for a 5.0. the 5.0 is pretty much the same power as a lightning 5.4 and I know the 4.6 and 5.4 have the same bolt pattern but I was wondering seeing if because the lightning came with the 4r100 if the bolt pattern was different or not. I'm thinking I might use the 4r100 and mount it up to the 5.0.
Old 02-16-2017, 06:32 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
I picked 2002 as a sample year. Ford lists part number XC3Z7005AA for the 4r100's tranny case for a 5.4L. They did not specify Lightning or not so 5.4L Lightning and regular F150 5.4L have the same tranny bolt pattern. But then you switched to 5.0L. Which one?
Old 02-16-2017, 10:02 PM
wa-sleeper's Avatar
wa-sleeper
Sorry what I'm trying g to say is the 4.6, 5.0, and the 5.4 have the same bolt pattern for the transmission. But I was wondering if the lightning is different because it uses the 4r100 or if it was the same as a standard 5.4 because I would like to use the 4r100 on the coyote 5.0 because they are a awesome strong transmission.
Old 02-17-2017, 04:31 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Modular V8 pattern
  • 4.6L SOHC/DOHC V8 (later castings, F3VE and up)
  • 5.0L Coyote DOHC V8
  • 5.4L SOHC/DOHC V8
  • 6.0L Navistar Power Stroke DI turbodiesel V8 [5R110 Automatic Only]
  • 6.2L Boss SOHC V8
  • 6.4L Navistar Power Stroke DI twin-turbo diesel V8 [5R110 Automatic Only]
  • 6.7L "Scorpion" Ford Power Stroke DI turbo diesel V8
  • 6.8L Triton SOHC V10
Old 02-17-2017, 06:40 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Whether the bolt pattern lines up or not aint gonna be the problem. Running the trans is gonna be the problem.
I'd hazard a guess whatever system they have that communicates with the trans in the new 5.0 and tells it what to do and when to do it, aint gonna be compatible with the 4R100.
Stewart
Old 02-17-2017, 06:46 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Stewart_H
I'd hazard a guess...
I shouldn't be guessing.
@Mark Kovalsky
Stewart
Old 02-17-2017, 09:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,573 Likes on 1,051 Posts
All 5.4L have the same bolt pattern, Lightning or not. The Lightning 4R100 has a 5.4L case with diesel internal parts.
He will probably need an aftermarket trans controller.
Old 02-17-2017, 10:32 PM
Stewart_H's Avatar
Stewart_H
Thanks, Mark.
That's why I shouldn't be hazarding guesses. Let the pro's advise.
Stewart
Old 07-02-2020, 05:29 PM
BackWoods NSpace's Avatar
BackWoods NSpace
BackWoods NSpace is offline
I've got same problem with truck I bought.
1991 f150 extended cab. It has a 5.4 in it . since research ing it so far ppl say that it had to be a motor swap...?
Old 07-03-2020, 08:46 AM
Johnny Paycheck's Avatar
Johnny Paycheck
Johnny Paycheck is offline
What’s the question?
Certainly, if your truck is sporting a Triton 5.4, it’s not factory issued. The f150 v8 options that year were the 5.0 and 5.8.
Otherwise, it’s not uncommon for someone not versed on their cubic inch to liter conversions to call a 351 a 5.4 when it actually is a 5.8 (or a 5.4 a 351 when it is actually a 330).
tazaxx
Modular V8 (4.6L, 5.4L)
11-11-2012 02:23 AM
guitaristman10
1997 - 2003 F150
07-30-2006 10:04 AM
silly34
1997-2006 Expedition & Navigator
03-17-2005 09:35 AM
ExplorerSp0084
2004 - 2008 F150
11-07-2004 08:50 AM
DZRT4X4
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
06-01-2004 09:51 AM
Quick Reply: Lightning 5.4 and non lightning 5.4
