K&N cool air intake - Ford Truck Enthusiasts Forums
K&N cool air intake
Old 02-14-2017, 06:31 PM
Dan Kacz Dan Kacz is offline
Dan Kacz is starting off with a positive reputation.
K&N cool air intake
I was thinking about adding a k&n cool air intake on my 95 Bronco 5.0 w/ mass air flow. Is it worth it? And what happens to the Air Charge Temperature Sensor? Or am I better off getting the filter keeping my stock box?
Old 02-14-2017, 08:29 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Do not put an oiled filter in front of your MAF sensor.. unless you like replacing it shortly after you clean and re-oil the filter or there abouts. Beside.. unless the K&N comes with a completely enclosed airbox it's actually a hot air intake. Yes the K&N will outflow the stock air filter but the fact is there is nothing restrictive on that motor upstream of the cylinder heads so the money you're gonna spend will just buy you some noise.
Old 02-15-2017, 12:14 PM
Quote:
Thanks that's is something I wanted to hear, it is mostly a daily driver untill I want to have a little fun now and then. I am almost due for an new air filter and I'll just keep her where she at and if it runs good I guess don't mess with it.
Old 02-16-2017, 04:59 PM
Bubba Jones's Avatar
Bubba Jones Bubba Jones is offline
Bubba Jones has a good reputation on FTE.Bubba Jones has a good reputation on FTE.Bubba Jones has a good reputation on FTE.
I will say that I did purchase the K&N FIPK kit for my 96 Bronco when it had the 302 motor in it. I did notice a very SLIGHT performance gain in around 4th and 5th gear at higher RPMs (because I no longer had to downshift on a slight incline on the highway that I drove everyday.)
Overall, it averaged my about 1 to 1.5MPG increase with the filter setup on there with the 7+ years I had it on.
It didn't seem to hurt my MAF sensor, but I was pretty careful on oiling. I know oiled filters CAN mess with the sensor like Conaski was saying and that's defiantly something you want to be very careful of because of important and expensive that sensor is.
I've heard K&N filters don't filter as well as paper filters either which I would believe. The previous owner put a K&N filter on the powerstroke engine I have and the turbo wheel was in terrible shape. I since have replaced the filter with a larger conical paper filter and things are much better.
So overall, the K&N filter setup will probably yeild you a TINY bit better performance and small MPG gains, but you'll have to be pretty careful with the oiled filter setup and realize the cost/benefit analysis. For me having it on 7+ years, it did make a positive difference for me, but if you don't plan on keeping it that long, it's a pretty expensive setup on a stock truck.
Old 02-16-2017, 10:30 PM
Thunderhorn's Avatar
Thunderhorn Thunderhorn is offline
Thunderhorn is starting off with a positive reputation.
Okay, maybe i am a bit closed minded but here is my take on the subject. Absolutely DO NOT change out to an oiled filter. As a mechanic I have done dozens of aftermarket to stock reversions due to people ruining MAFs as previously noted. Also I dont want to say Bubba is wrong but I find it highly hard-to-believe that he gained even that much of a difference by changing to K&N. Heres why: If stock air filters were restrictive enough to decrease performance, and an aftermarket filter had less resistance, then NO air filter would have even less resistance and therefore increase performance even more. (obviously you wouldn't want to go filter-less) however I have on one occasion on my Kawasaki Vulcan when I wanted to test this theory. I used HIGHLY restricted filters, newly serviced K@N filters, and no filters at all and determined that I could not tell the difference at all. now obviously this one experiment doesn't make me an expert but it is something to consider. Another thing is that on an EFI engine the fuel will be adjusted to match the air intake, and a stock filter is designed to far exceed the highest amount of air a particular engine ever consume so even clogging up a filter a bit wont bring the total air below the acceptable threshold. on the note of cold air, it has already been stated that aftermarket air boxes arent usually any better, and I second that. and finnally, even all those things aside, I am a naysayer of oiled filters for our trucks because oiled filters LOVE dust, that is they ARE indeed better at collecting fine dust than a dry filter (this is their actual purpose) and if you are planning on going offroad your oiled filter will very quickly aquire a nice layer of mud, even if lightly (properly) oiled. I have also seen this an many occasions. If you are okay with servicing your filter after every adventure AND on a regular basis anyway, then disregard this point. Again, I am no automotive engineer and I don't want to say I know better than anyone else on this subject. But those are the conclusions I have arrived at after considering the experience I DO have.
Old 02-17-2017, 10:54 AM
Quote:
I had the same idea on my mind about it, it's a strong running motor regularly maintained with just over 208. And I just dont want it because it looks cool and give me issues later on down the road.
Old 02-21-2017, 10:45 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
The proverbial case of "don't fix what isn't broken". Listen to the guys and don't install that filter, nothing to gain and much to lose since day 1, when you receive a needlessly thinner wallet. And welcome to our little corner of the forum
Old 02-21-2017, 11:33 PM
Quote:
Exactly, just installed a fram filter. Always do research before making any car add ons. Joining the forums is one of the best thing I've done. Before hand I joined a old Ford truck page on social media posted the same question and nobody responded in weeks.
Old 02-23-2017, 09:03 PM
Black Ford XLT's Avatar
Black Ford XLT Black Ford XLT is offline
Black Ford XLT is starting off with a positive reputation.
I must agree with most said in these posts and not having mass air (92bronco)I did also get a Bump in fuel mileage. Hot air intake yes (I kept my hose from the front dam to the air bo neatly tie wrapped) up near my k/n where it would have fresh air. Dirty it can get and lucked out many yrs back in finding a bronc in a bone yard that has one installed (2 mos wrecked) (nearly new)I pulled to have 2. I have had it installed for 10 plus years and cannot go back to an air box. Good luck. TR
Old 03-06-2017, 07:31 PM
Joe Robertson Joe Robertson is offline
Joe Robertson is starting off with a positive reputation.
I just bought the kn filter for my 95 5.0L so I guess I'll take my chances but may not oil it when it comes time because I know you have to be careful not to over do it. I put one in my Saturn aura 3.6L which is a 5.5 sec 0 to 60 and I could tell a significant increase in acceleration and response plus it sounds good too. jmho
Old 03-08-2017, 07:33 AM
'96XL '96XL is offline
'96XL is starting off with a positive reputation.
Be careful. They are over oiled from the factory. I used to think K&N helped. However, it was just in defense of the $$ I had spent.
Cold Air Intake mrdanielcruz Ranger & B-Series 4 04-20-2016 11:59 AM
K&N air filter, good or bad Winmagbar 1994.5 - 1997 7.3L Power Stroke Diesel 57 01-28-2016 07:15 PM
Alternate Air Filter to K & N question bigreentruck 1999 - 2003 7.3L Power Stroke Diesel 5 05-30-2015 06:59 AM
v10 cold air intake littlejohn6977 Excursion - King of SUVs 2 02-07-2009 10:45 PM
K&N Filter VS K&N Cold air intake VS mac air intake homer4.2 3.8 & 4.2L V6 32 07-01-2004 03:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
