Finally!! back in a EX but have ? 10" lift
Old 02-14-2017, 10:07 AM
animal70X7's Avatar
animal70X7
animal70X7 is offline
Been without an Ex for a few years. Just bought a 2000 with 10" BDS lift. Anyone know for sure what size tires I can run. Debating skinny (13.5) vs wide (15.5+) Last one took 8" to run 35X15 on a 16X12 rim and still had to have 2" spacers in the bumper to keep from rubbin. Also, I have noticed on ebay that aftermarket square mirrors (08 style) can be had for less than 150 for the pair. Are they worth getting?
Old 02-14-2017, 10:27 AM
mecdac's Avatar
mecdac
mecdac is offline
Exclamation
No, step away from ebay: try 1A auto instead.
Old 02-15-2017, 12:54 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
10" lift, you could run 40's if you have the gearing
Old 02-15-2017, 05:23 PM
brandon_0384's Avatar
brandon_0384
brandon_0384 is offline
Pictures required!
Old 02-16-2017, 01:36 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
With mirrors you get what you pay for. The plastic is about the same but the mirrors themselves are crap. Lots of distortion
Old 02-16-2017, 05:55 PM
animal70X7's Avatar
animal70X7
Old 02-16-2017, 05:57 PM
animal70X7's Avatar
animal70X7
Found a source for axles. 4:30's SRW shipped 670, 4.88/5.38 800 DRW. Any ides how much is involved in converting to SRW?
Old 02-17-2017, 09:07 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Heck, with 10" of lift, keep the DRW and add rear fenders. Gears inside the pumpkins will need to match if you want to use 4x4 successfully.
Old 02-17-2017, 12:20 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
What motor do you have and what gears are you thinking that you will be needing with the new giant tires?
I was quoted $2000-ish for changing both front and rear gears with bearing kits from my factory 3.73 to new 4.88s. But then I got an even better deal on a set of axles already setup and broken in with 4.88s for $1200. In the end it might work out to be a better deal to just have your current gears swapped out rather than messing around with the heavier F-450/550 axles to make them work.
Old 02-17-2017, 12:29 PM
pirate4x4_camo
if you have the parts then it's just a swap, if you have to purchase the parts then just sourcing the correct complete axle will likely be less expensive and involved. $800 is not any great deal that makes it worth the hassle. You should be able to find the correct srw axle for the same cost
Old 02-17-2017, 06:57 PM
animal70X7's Avatar
animal70X7
4.30 is the only direct swap I can find. If you have a source for 4.88/5.38 in SRW, please share....
Old 02-17-2017, 07:19 PM
pirate4x4_camo
For a complete axle swap the 4.3 is your option.
Gear change if you want a different ratio
Old 02-20-2017, 08:53 PM
dvldog458's Avatar
dvldog458
dvldog458 is offline
You can run 40" tires with 10" lift.
I also installed 4:56 gears with stock axles .
Old 02-21-2017, 08:57 AM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
I bought towing mirrors from ebay for my 2000 Ex....I have zero distortion, heat function works as does motor function to adjust mirror. I have had them for 3+ years and only reason I had to replace one was my wife decided it was a good idea to sideswipe a garbage can at speed!
Old 02-21-2017, 09:37 AM
animal70X7's Avatar
animal70X7
Which ones did you buy?
Quick Reply: Finally!! back in a EX but have ? 10" lift
