Rear brake spring placement? - Ford Truck Enthusiasts Forums
Old 02-14-2017, 12:04 AM
rterril02 rterril02 is offline
rterril02 is starting off with a positive reputation.
I'm doing a 10.25 swap in my 86. It had a 10.25 originally but the pinion seal was leaking and instead of fixing I chose to get a newer version of the sterling with the longer splined pinion. I have the axle mounted (and didn't have to shorten the drive line) and when I took off the brakes at the beginning of the switch I forgot to take a picture of how the springs were. The pictures are of what I have done so far. There are some springs left over, one of the shoe hold down springs and two of the purple springs that resemble the blue spring I have on the bottom. Did I get the adjuster right? Also what are the silver u's for, the new parts came with 2.Left over parts, one shoe gold down spring and two purple springs.
Wheel cylinder before i installed parking brake assembly.
Am i missing something.
Another open hole?
Do i have the adjuster assembled correctly?
Old 02-14-2017, 06:06 AM
chillman88 chillman88 is offline
chillman88 is starting off with a positive reputation.
I've never done brakes on a sterling, but it looks to me like you're missing a spring on the adjuster assembly?
I'll leave it for someone else to confirm or deny but from the drum brakes I've done usually there is a spring maybe in that little slot to the left of the L in the picture with the adjuster on it?
EDIT: I see it in the picture above it now, nevermind!
I have had kits accidentally come with extra springs before so idk.
Old 02-15-2017, 12:13 PM
Thanks chillman88. I guess all I needed was piece of mind. On another forum someone posted a diagram for the brakes.
99-04 12 volt power point with roll-up door Nicmike Ford Truck Parts for Sale 1 02-17-2017 07:50 PM
99-07 A pillar trim and grab handles - prairie tan Nicmike Ford Truck Parts for Sale 1 02-17-2017 07:49 PM
99-07 Motorcraft vacuum pump for 7.3L or 6.0L Nicmike Ford Truck Parts for Sale 4 02-17-2017 07:45 PM
Vacuum help needed! TheGreat460 1987 - 1996 F150 & Larger F-Series Trucks 4 02-14-2017 11:30 AM
99-04 grey cup holder - with spring arms Nicmike Ford Truck Parts for Sale 2 02-14-2017 12:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
