Indirect injection to direct injection - Ford Truck Enthusiasts Forums
Old 02-13-2017, 06:40 PM
Daniel Cook Daniel Cook is offline
Daniel Cook is starting off with a positive reputation.
I know this sounds like a crazy idea but I'm hoping someone has tried it or has some information on it. I've got a 7.3 idi with a turbo from factory. my idea is I want to have the heads machined so they can hold Cummins 12 valve injectors and will protrude from the heads making it a direct injection 7.3 but it will still run off of the stock mechanical injection pump. If anyone knows anything that could be helpful to this project I'd be very fearful thank you
Old 02-13-2017, 06:45 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Not doable without spending waaaaay too much. It would require custom pistons, entirely different heads, and a ton of other work.
There is a company that offers a mechanical conversion for the 7.3psd for about $10-12k.
Old 02-13-2017, 08:05 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Yeah, I'd do this, if you want a mechanical direct injected engine. Or, just get a P-pumped cummins.
Really, you wouldn't gain anything by doing what you want, at all. The IDI design is a pretty good design, because you can use a very sloppy pump design like ours is.
I personally prefer an IDI design over a DI design because injector spray is far less critical. As long as the fuel comes out at the right time, you're good.
And even if it doesn't, it might create some smoke or a limp, but the engine will handle it.
On the other hand, a DI engine can melt a piston if an injector goes bad.
Old 02-13-2017, 08:32 PM
Ford_Six's Avatar
The only real downside to the IDI design is the loss of combustion heat through the pre chamber. That robs about 20% of efficiency on most IDI designs.
Old 02-13-2017, 08:41 PM
Macrobb's Avatar
And yet, fuel economy doesn't seem to be 20% less.
Old 02-13-2017, 10:55 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
The real question is... why would you want to go to smaller injectors? Besides that, what is it exactly you are trying to accomplish by "converting" to direct injection? Emissions not-withstanding, im not convinced DI is superior to IDI. IDI technology was to replace DI afterall. You do lose more heat to the head due to larger surface area, this can be mostly negated with heat coatings. Even so, the literature ive read puts it more around 10%. On top of that, DI pistons have a much greater surface area than ours. Instead of putting the heat in the coolant, youre putting the heat in the oil, but its still lost all the same, if not more so with DI, as aluminum absorbs / dissipates heat faster than cast iron or iconel.
1994.5 f250 7.3 core support???? Kyle_94obs 1994.5 - 1997 7.3L Power Stroke Diesel 2 08-17-2016 09:52 AM
How to install 7.3 idi injection pump. CrispyWafer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 07-27-2015 07:39 PM
Why did ford go from an injection pump to heui on the Powerstroke? trevorrules 1987 - 1996 F150 & Larger F-Series Trucks 19 04-11-2015 12:05 AM
'94 7.3L Stock HP and Torque ratings Black Cowboy 1994.5 - 1997 7.3L Power Stroke Diesel 8 12-23-2007 03:28 PM
Hope I Am Doing This Right lanceeliuk New Member Introductions 1 07-25-2006 12:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
