94 302 4x4 EAOD Rod Knock
Old 02-13-2017, 10:26 AM
OverLoader's Avatar
OverLoader
OverLoader is offline
Hi I've got 1994 f150 4x4 with 302 HO FI EAOD and it got a rod knock last year. I just bought a 302 carbed engine( dont know if its HO or not) married to an AOD that was put in bronco(was in a fire) that originally had 351.
. I just don't know if I should or will AOD (no info on if it's strong or not) mount to easily to existing transfer case on f150. Or if carbed 302 will work with EAOD. And i dont know if I was to switch from carb to EFI what that all entails, don't know if firing order is the same. Also can get 460 motor and transmission but than again don't know what all that entails, any info would be great thanks.
Old 02-13-2017, 10:45 AM
OverLoader's Avatar
OverLoader
Oopps
Its actually a E4OD transmission
Old 02-13-2017, 11:08 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
A carbed engine will work with an E4OD if you get an aftermarket transmission controller. PCS and Baumann are two companies that make them.
Old 02-13-2017, 04:40 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,360 Likes on 1,074 Posts
Couldn't you just use the carbed long bock and keep the rest of the '94 drivetrain?
Old 02-13-2017, 05:14 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
That AOD is a light duty trans and probably wont last very long in a truck.. I would suggest you repair what you have, as a controller to use a carb with the E4OD will run in the neighborhood of $400-$500 new. You might do better on the price if you can find a good used one, but I'm betting that won't be too easy as you don't hear about many of them used.. If all that was wrong with the original engine was a rod problem and the top end was OK I would just put a short block in there and call it a day...
Old 02-13-2017, 09:56 PM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Thats what I am thinking too. The E4OD is a good trans, especially if it's ever been brought up to 95'+ spec's.
What year is the carb'd motor? I'm wondering if it's flat tappet or roller lifter.
frankosd
10-04-2018 09:49 PM
dillon.proctor173
03-06-2011 06:04 PM
hatchet
09-16-2008 01:38 AM
floyd rogers
1997 - 2003 F150
03-22-2008 12:00 PM
muddiver150
Engine Swaps
17
07-23-2007 08:48 AM
Quick Reply: 94 302 4x4 EAOD Rod Knock
