8BA V8 air cleaner
Are you using the original type air cleaner? If so; Are you sure you have the right carburetor top? There are two kinds.
The carbs in the first picture have a straight horn. The original air cleaner won't reliably clamp onto them.
The carb top in the second picture has the tapered horn. The original air cleaner is made to fit tightly onto it.
The third picture is a closer look at one of the straight type.
Also shouldn't the truck carb, the one with the bevel, have a gasket of some sort? The carb on my 54 does.
I'm not sure what you mean by a little wiggly, but the air cleaner isn't the tight fit that you get with the bolt down the center of the air cleaner. Al the same time it should not vibrate when the engine is running. Make sure that your threads are clean on the screw clamp.
Spare parts I'm not using
HillBillyBuddha
01-24-2019 06:27 PM
Jasonnoel
09-23-2014 09:06 PM
41505379
07-19-2013 06:55 PM
Ratsmoker
08-01-2002 07:25 PM
