Starting motor without waiting for glow lights
Totally dependent on a bunch of different factors.
Diesel engines are "compression ignition." The piston compresses the air in the cylinder to a very very small percentage of the full volume of the stroke. When air is compressed, it heats up. Then, at the top of the compression stroke, fuel is injected in to the cylinder, and, if all is working as designed, the compressed air is hot enough that the fuel ignites, resulting in the power stroke of the piston.
If the engine can't compress the air enough to reach the requisite temperature, then the air/fuel mixture won't ignite. Glow plugs are intended to help heat up the air in the cylinder to aid in firing.
Battery and starter strength, compression, air temperature and the temperature of the block and other metal components all come in to play. A weak engine will have trouble starting even in above freezing temperatures, while a healthy one will start without issue in sub-freezing temperatures even if all the glow plugs aren't working.
A weak engine as in, a low compression engine, or weak engine as in, a weak component that you mentioned, resulting in a non fire situation
Warm cylinders should cause your engine to start sooner and should require less fuel to start. Your starter may also last longer by not having to crank so long.
This little red light may stay on for a minute or longer, depending on how cold it is..
BBD
Voltage
I have one of these:
https://www.amazon.com/INNOVA-3721-B...hter+voltmeter
Pretty easy to tell when the plugs are on with this.
