Quick injector question
I hydrolocked my 2005 f350 6.0 and have cleared it, it was the number 4 injector, but when I pulled it out, the tip is black (I'm assuming it's burned) and the copper washer was are up and not on the tip. I was able to retrieve what I believe is most of the washer. My question is, with the washer being are up, what happened? The hold down screw wasn't tight, but I guess that was from the washer being gone. Should I even attempt to put a new washer on this injector and give it a shot, or just replace the injector? It's a stock injector and I've heard they rarely go out on a 2005+ 6.0, and I'm just curious if I'm throwing money away replacing it. Thank you!
Clean the cup, re-ring the injector and blow out the hold down bolt hole and see what happens. 10 bucks for the o ring kit from alliant vs 203.50 + core for the injector. Not sure what you mean by the washer being "up". It should seat on the base of the tip with the 2 raised parts toward the injector and the single raised part towards the tip. Tip is black because it is in the combustion chamber. If the body of the injector is black past the tip then you have a leaking or blown copper washer. 24 lbft for the T40 and 26lbft for the T45 hold down bolt.
Did you have a code during/after this happened?
I think I would stick a Ford reman back in the hole. Whoever told you the later builds rarely go bad was mistaken, does not matter what year 6.0 one has. They can and do go bad, depending on the truck. That is not to say you might be able to use that injector yet and go another 50k miles. It's not #5 or #7 so you have that going for you if it does crap out.
When you say the washer being up, if you mean it was up resting on the injector body that is correct. It seats between the bottom of the nozzle body and the bore cup, hence the name "crush washer"
I would agree, if it was mine would be throwing a reman FORD only back in that hole. I think Randy had this very issue after he did an injector o-ring thread.
5 and 7 are the worst two injectors to get at, in the event the OP decided to take a chance and reuse the injector, at least #4 is one of the easiest to access
Bubble test the truck when its done was the lesson I learned, may have saved it.
I wasn't getting notifications on these posts. I did put a reman injector in it. My phone must have typed the wrong word, because the copper washer wasn't "being up" it was "ate up" as in it was destroyed. I fished all the little pieces I could out of the bore, cleaned it up and installed a reman ford injector yesterday that a buddy had never used. Unfortunately the truck is an hour away, and it got dark so I had to call it quits before it ran. All I have to do is mount the FICM, air filter, and hook some hoses up. I didn't have a way to get both trucks home anyways so I called it. The bad injector was extremely black on the end, way up past the tip. I pulled #2 and #6 just to look at them as reference. I knew the knocking I heard when I got it to fire that one time was going to be the problem, and it came from the drivers side so that's where I started, and it sure enough was right. It was super dark where I was, so if say the smoke I was seeing was unburnt fuel that I mistook for coolant.
If you removed any other injectors then you should reseal them before they go back in. That copper crush washer is meant as a "one time use" seal. The others you could get away with reusing if needed, but I wouldn't risk the crush washer especially when you're going through exactly what you're explaining.
EDIT: Mike beat me to it, but I will leave the info here because it is important to help prevent the same issue you have.
