Bronco Quarter Panel Replacement
Hey All,
I've had the Bronco kind of put away for a while, I've been doing rear quarter panel replacement when I've had the time. I have the new panel tack welded up but I'm not sure if I should fill every single gap with a bead? It just seems like it's to time consuming and I suck at welding.
I was thinking now that its welded up I could grind it all down and then do fiberglass filler. Any opinions?
Doing the first rough cut.
Lining it all up
Welded in place
Lining it all up
Welded in place
