Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 08-28-2003, 11:56 PM
bbyers bbyers is offline
Garage is empty, add now
bbyers is starting off with a positive reputation.
Unhappy Idle Air Control Valve
Idle Air Bypass Control Valve has gone bad and truck has a terrible humming noise when it is at idle (600 -900 rpm)
Dealer wants $80.00 for the part. Anybody know of a place to pick one of these up other than the dealer. Have check AutoZone, NAPA, Advanced and several other parts dealers. Can't find it
It is for a 2001 F-150 SuperCrew 4x4
Thanks
Brad
  #2 (permalink)
Old 08-29-2003, 12:14 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi Brad and welcome aboard
Even if you can find an aftermarket IAC I would still buy the genuine Ford one. In my experience most Ford parts of this nature are better than aftermarket ones.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #3 (permalink)
Old 08-29-2003, 01:06 AM
AegisSailor's Avatar
AegisSailor AegisSailor is offline
AegisSailor is starting off with a positive reputation.
I got one at Autozone for $70. It works, but just doesn't seem quite right sometimes. I would follow Dave's suggestion and spent the extra $10 for the Ford part.
__________________
Roger
Red 2004 F-150 4.6L 4WD Automatic
  #4 (permalink)
Old 08-29-2003, 06:52 AM
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is starting off with a positive reputation.
Brad here are some online Ford parts websites;
fordpartscheap.com
fordpartsonline.com
__________________
2007XL R/Cab,4.2 V6,auto,cruise control
The anticipation of death is worse then death itself!
  #5 (permalink)
Old 08-29-2003, 08:54 AM
Thanks Guys
Glad i found this site!!!!!!!
Third Ford and lovin evey minute of it, except for this howling noise.......how annoying!!!!
Brad
  #6 (permalink)
Old 05-25-2007, 08:21 AM
dberry1052 dberry1052 is offline
dberry1052 is starting off with a positive reputation.
You can try to take the part off and clean it thoroughly with Carburater cleaner. The idea is to clean the carbon buildup from the valve body. My truck woke up one day and decided it didnt want to idle at all. A tow truck later, then delivered to the mechanic, it started and ran normally. He diagnosed it properly as the IACV. He said it is common and the jolting of the tow truck is sometimes enough to loosen the carbon. Once I got it home, upon advice of the mech, I took it off and cleaned it and saved myself 150.00. It worked. 4 years later, it is still working fine, although I think it's time to clean it again. The other morning it would not idle. I used the trick he told me previously, " if it ever does that, tap on the valve with a screw driver. It will loosen up the carbon enough for it to idle. So I know I'll be pulling it again and cleaning it this weekend.
  #7 (permalink)
Old 05-25-2007, 01:07 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
I got one from Auto Zone for 48.00 and it works great.
  #8 (permalink)
Old 05-25-2007, 01:32 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
I can get one from the dealership for $60. A friend of mine works there...
__________________
-2006 Dodge Ram 3500 ThunderRoad ed. CTD, 6-spd, and 4" straight pipe!
-1988 F350 4x4 7.3L IDI
-1978 F150 4x4 - 466ci/4-spd/4" lift/35's
-1978 F150 4x4 - 351/C6/Flatbed
-1978 Bronco - Parts
  #9 (permalink)
Old 05-25-2007, 03:11 PM
galaxie641 galaxie641 is offline
galaxie641 is gaining momentum as a positive member of FTE.galaxie641 is gaining momentum as a positive member of FTE.
Auto Zone, NAPA or any other should have them, got mine from NAPA for around $40. Just ask for an IAC or Idle Air Control Valve, the Bypass thing is probably confusing the poor parts monkey behind the desk.
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'92 Grand Marquis
'97 F150 5.4L
'08 Bullitt #3947
  #10 (permalink)
Old 03-02-2010, 09:02 AM
wacp2 wacp2 is offline
wacp2 is starting off with a positive reputation.
Can the IAC Valve can cause the engine to shut off when is running, when is low idling
  #11 (permalink)
Old 03-02-2010, 09:42 AM
Idle Air control Valve
that's exactly the symptoms..poor idleing..engine will only idle if you give it gas and if you do not, the engine will die. Try this, find the Valve, just tap on it with thehandle of a screwdriver and see it idle improves. If it does, you know you've got the clean the valve or replace
  #12 (permalink)
Old 03-02-2010, 09:59 AM
IAC Valve
I want to konw if with the IAC Valve for gasoline can i use LPG
  #13 (permalink)
Old 03-02-2010, 11:33 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a good reputation on FTE.KhanTyranitar has a good reputation on FTE.
The problem is that all too often you buy an aftermarket part and it works about as well as the part you are replacing.
Tags
2000, 2001, 2004, 2005, 97, air, control, explore, f150, ford, idle, location, ranger, v6, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
