Trim removal tips and trick,special tools?
#33
Although not identical to the 379852-S3 clip, a slightly smaller clip was used on the 64/65 Falcon that is reproduced and available from Mac's. It is 1/2 x 3/8 x 11/16 stem. If you turn it with the 1/2" long side vertically it should work. it is available in a lower dash trim kit that includes 4 clips and 6 screws, p/n 90-14526-1 for $7.49. The screws can be used to install the Custom Cab sweep style gauge cluster.
Also, both the trim at the windshield and the lower dash are the same: C0AB 604439.
These style clips are also available in bulk but I don't know what sizes are available yet. If I can crack the code on the sizes I will post a link where we can get these for dirt cheap.
#34
I know we were PMing about this just now. Look up Section 030 Page 5 for the moulding and the clips are just below them. I added the word (short) for my own clarity.
RH Instrument Panel Moulding C4TZ-8104332-A 1
LH Instrument Panel Moulding (short) C4TZ-8104333-A 1
Clip 379852-S3 8
These clips are larger than the
Instrument Panel Moulding Retainer C0AB-6404439-F
Chad
Clip 379852-S3 8
Chad
#36
Well don't lose any of the upper clips because I don't think anyone makes a good replacement.
The clip that is reproduced is 1/2" on the long side, 3/8 on the short side. By installing it vertically instead of horizontally it could work in the lower dash trim.
I've also considered using a modern plastic clip with a flat head and the multiple flat side barbs. There are several vendors who sell this same style clip in bulk, but they don't give dimensions. They came in at least 3 different sizes and were used by both Ford and Chrysler.
#37
#40
Interesting place from the sound of it. Robert seems to have a login here (Robertcontr) but he hasn't logged in since October 2014 timeframe.
https://www.ford-trucks.com/forums/1...indshield.html
Chad
Chad
#42
Thanks for the info!!
#43
Unless Robert has a secret stash of NOS stuff, I suspect any clips from him will be take-offs from trucks they have dismantled for parts.......
James
James
emgee
07-10-2019 01:53 PM
girlwithatruck
27
07-28-2009 07:47 AM
