Where does this mount?
2008 F250, 6.4
I had to install a radiator during my final inspection I found this vacuum regulator hanging down by the lower radiator hose.......well clearly is does not belong down there.
So it is on the passenger side, your are looking at an empty battery box......so it must mount someplace......has one hole and one slot for mounting. Its been a looong time since cant remember removing something much less not being able to find were it mounts..........
The upper right illustration should answer the OP's question, regarding mounting location. As far as the part itself, that is the PVH (Pulse Vacuum Hub) solenoid. That is the part that directs vacuum to the front hubs to engage/disengage the front hubs to the axle during 4x4/4x2 commands.
kraylake
01-05-2012 10:54 AM
79-400-POWER
08-16-2007 03:27 PM
