Does anyone know the torque specs for the rear main seal on a 95 7.3l powerstroke?
The torque for the rear main seal plate on pre-98 7.3 is 90 in lbs at the most. The older motors used smaller grade 10.9 M6 1.0 x 15 bolts which are only good up to 98 in lbs dry torque. If you go by the 180 in lbs for a newer engine you risk snapping your bolts off in the block.
