TECH ==== CDR SERVICE
on
Some of the cooling tubes that I could see in my old radiator were plugged with pieces of cured RTV. Who knows how much of the radiator was plugged or HOW to get it out?! Some good sized pieces were also floating in the top tank below the radiator cap. Good-bye to THAT radiator! Probably from a messy thermostat or water pump job, so yeah, some people way over do it with the sealants.
What I WAS concerned about is the old and hardened grommet. That's also why I didn't push back and move the CDR all over the place to get it out. I didn't have a replacement and no lead on where to get one but this job had to be done!
With the proper thickness of the gasket to the intake you shouldn't have to push it back more than enough to break the seal of the gasket loose from the intake and then it should come straight up and out. I also wanted an air-tight seal so the CDR would balance the pressure and vacuum properly. I'll replace it with a new grommet and new CDR next time! Then I won't need a sealant for an air-tight/water tight seal.
Otherwise the 'Do not use sealants' unless specified is the generally accepted rule and I agree.
.. put some M40 all over the lid rope seal on the bottom of the lid rejuvenating - and making that air tight .. and cinched it all down again ..
I just need to get a START on where to find something that will work. I'll probably have to take a photo of it after removing a small piece and with some measurements send it out to some distributors or manufacturers. There weren't many of these Banks Power Pack systems made and sold. Originally I think that they were offered as a dealer option and then possibly aftermarket but a short time later, by 1988 they were set aside and forgotten about due to the new Banks Turbochargers.
I'm confident that when I have the time I will find something that will be ideal.
About your air-cleaner and filter work:
i expect she'll pull a bit harder .. run a little cleaner .. and probably see improved fuel economy ..
all in well worth the effort .. okay .. bye for now .
Leroy
Leroy
I don't want to wander off topic but I often do. Air cleaner assemblies are somewhat on topic since, like the CDR, they are related to the Intake.
on
But no joke, your post did expand my knowledge and perceptions considerably.
I was thinking specifically about your projects while I was writing my first reply here. I have a couple of quick and simple-to-answer questions about what you posted here but I am much too tired to write those so they'll have to wait.
