Synthetic Oil - Any reason not to use it?
My 460 has a main rear seal leak which loses less than 1/2 a quart of oil per month on regular motor oil. I tried synthetic at the same weight and it started leaking about 1 1/2 quarts per month so I switched back.
So if your truck leaks any oil from anywhere, it will probably get worse with synthetic. If your's doesn't have any leaks then it certainly won't hurt.
I run that oil in the summer. Mobil 1 high mileage 5w30 is my winter oil. Recently had the valve covers off the engine and there was very minimal soudge(I do a lot of short trip driving and cold temperatures take their toll).
I am running mobil 1 extended performance in my 351w. I just rebuilt it this fall, and after a hard break in on dino oil I wanted to help the bearings last.The flow at very cold temperatures was a major selling point for me. We've been down around -35F a few times this winter. Cheap oil is crazy thick at that temp. Block heater plus good oil, the truck fires right up. I'll be sending in an oil sample to Blackstone labs shortly, since I've got 5k miles on the oil and want to know what a good change interval is. By far, regular changes matter more than oil type overall, but synthetic does offer better protection at extreme ends of the temperature spectrum.
One thing to consider is that you have a flat tappet cam in that 460, most modern oils lack the ZDDP levels that motor was designed for. Not as big of a deal with the cam broken in but I'd be looking for higher levels than lower. I know some Mobil 1 oils have pretty low content and others are surprisingly high. The info is on their website, might take some digging to find.
I've run full synthetic from day 1 (0000008 miles on the odo) on my 96 HD 250 4x4. Never had any motor-related issues-ever. No leaks. Currently has 360k on it and has never been opened. Worst unrelated to oil thing about this engine are my exhaust manifolds-currently on my 4th pair.
On my 2nd truck, 95 250 4x4 which I bought w/120k on it, switched over to full synth when I changed the oil for the 1st time under my ownership. At just under 200k I have no leaks and winter start-ups are easy.
I don't think anyone can come up with a negative for using synth oil.....on the contrary, I'd think there'd be MORE negs using conventional oil when you weigh the 2 against each other.
Synthetic is excellent, I personally used royal purple 5w-20 in my 93 460. Ford back-specced the 460 and most other engines that are 93 or newer to 5w-20 oil. However I am probably gonna move up to 5w-30 or 10w-30 to reduce consumption, blowby, leaks, etc. But one nice thing about royal purple is it still contains a sufficient amount of zinc which is good for our flat tappet cams.
low and fast
08-18-2009 07:20 PM
FordF350Baby
06-11-2009 09:12 PM
