NO electricity - Ford Truck Enthusiasts Forums
NO electricity
Old 02-10-2017, 09:47 AM
B.Les B.Les is offline
B.Les is starting off with a positive reputation.
NO electricity
First, Thanks everyone for all the help. So I have a 1986 F350 6.9. The truck is creeping up to 400k so I imagined I'd have trouble like this before too long. Just the other day, I had driven my truck to work, and a couple hours later I had to leave the lot to go on a parts run. I drove about 30 feet and then the truck just died. And I don't mean it stalled out, I mean that EVERYTHING went dead. Engine, radio, all dash instruments, even my headlights wouldn't come on. I monkeyed around and checked everything. Cleaned my grounds, tried to trace the wires as best as I could on the side of the road, broke out the volt meter and all, to no avail. Eventually, I gave up and just ran a hot wire to my fuel pump, IP, and jumped the glow plug controller and starter sol., and drove it 30 minutes home. It ran fine all the way, but I had no instruments or lights. Any ideas or leads that someone could point me too? I've already done some digging and checked what other people seem to describe as general problem areas in the wiring harness, but all of those connections are good. I'm really depending on this truck and I don't have a lot of time to spend looking for a needle in the haystack while I'm trying to balance full time work and college and home life. Thanks a bunch Y'all.
Old 02-10-2017, 10:07 AM
Realslowww Realslowww is offline
Realslowww is starting off with a positive reputation.
I had the same thing happen on my 82 F250 300 six and it was a relay going to the solenoid if I recall correctly. It's more than likely a relay in the beginning of the electrical line somewhere....
Old 02-10-2017, 11:36 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Did you jump the starter SOLENOID (ON the starter) or the starter RELAY (on the fender)?
Unless you or a previous owner has modified the truck, you don't have a hot wire on your fuel pump. It's mechanical. If indeed it's an electric fuel pump, what other mods does the truck have that haven't been disclosed?
Check for voltage at each battery, at the always-hot terminal of the glow plug relay, and at the always-hot terminal of the starter relay. Not sure about your '86, but technically, the original wiring layout on my '85 had the main power to the truck going from the passenger-side positive to the glow plug always-hot terminal, and THEN a wire from there to the always-hot starter relay terminal. Then all the accessories (fuse links) ran from that terminal on the starter relay out to the rest of the truck. Somewhere along the lines, they switched to running the main wire from the battery + to the starter relay terminal, which then acted as the junction to the accessories and to the GP relay. Electrically, it works out to be the same, but the wire tracing and chasing down the bad connection will be different. You'll just have to follow wires to see which way yours is wired, and check all those connections while you're at it.
When you ran the jumpers to emergency start the truck, did any of the accessories (exterior lights, etc) work?
Old 02-10-2017, 11:52 PM
Thanks for the info! Yes, I put an inline fuel pump in and blocked off the mechanical pump. Sorry. I should have mentioned that. And I jumped the starter from the fender. And yes, I checked for power going past the gp controller and all. And even with the emergency wiring I did, I had no other power anywhere in the truck. No headlights, turn signals, or dash instruments: oil pressure, temp gauge, or even voltage gauge. Its all dead. The though crossed my mind that maybe it was my ignition switch. However, I can't even get my headlights to turn on, which runs independant from the ignition. It literally has no power whatsoever. But, from what I can tell, the problem is not under the hood but under the dash is my best guess. Because I think I checked the wires under the hood good enough to determine their working condition. However, I am not dead set in that theory. Its got to be just one point that all the power runs through, because for EVERYTHING to go dead all at once would be too much of a coincidence if it were multiple bad wires/connections. Especially since I dont even have power to my headlights. Again, thanks for the info! Its greatly appreciated.
Old 02-11-2017, 12:30 AM
All the "wires" on the always-hot terminal on the starter relay are actually fusible links. It's possible one or all of them have burned out. They feed pretty-much everything in the fuse box. That would be the next thing to check.
Old 02-11-2017, 09:29 AM
Thanks Mad, sorry that is what it was on mine a fusible link. I mean no nothing notta power.
Old 02-12-2017, 12:56 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
if the wiring is stock all power for every thing comes from the large post at start solenoid on fender pass side, three large wires and the battery cable, 1 is the charge wire from alt, 1 is the main feed to glow plugs, 1 is the main feed to cab, all are fused with inline fusible links, they burn internally when they go out. that's the place to start....
Old 02-12-2017, 08:18 AM
big ole ford big ole ford is offline
big ole ford is starting off with a positive reputation.
It is almost certainly a blown fusible link by the starter relay, BUT when repairing it you must find out why it blew in the first place or it will happen again and second it is not ok to bypass a fusible link even temporarily lest you start an electrical fire. I dont mean to be an alarmist but I have set enough things on fire due to my own ignorance I dont want anyone else to have to learn that lesson the hard way! hope this helps
Old 02-12-2017, 05:33 PM
Quote:
Thanks! And when I did the emergency wiring, I made sure that nothing else was energized. ONLY the ip and the fuel pump. If I can hunt down whats causing the problem, I will certainly repair it correctly. This truck has been too good to me for me to not treat it right. Thanks again! I'll see what happens when I dig around.
Old 02-13-2017, 02:26 PM
He has a C6 tranny or stick, what happens with a newer electronic controlled E4OD if you drive with no power ? Will it go into gear but not shift correctly ?
Old 02-13-2017, 04:36 PM
^^^^^ Probably. You could jump power to the TCM, I reckon. 'Course, it would be prudent to jump power to the brake pedal switch as well....
Old 02-13-2017, 04:54 PM
So a C6 is definitely better for a Road Warrior zombie mobile ?
Old 02-13-2017, 05:15 PM
^^^^ Better than an E4Oh$#!+, yes. Not better than a T19 / ZF5. Roll-start a manual truck and you can just about run it off a 9-volt battery.
Old 02-13-2017, 08:43 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Quote:
Just pull the IP cover off and pull the little FSS lever out. Now, you can run it with /no/ battery! Killing it is harder, though(You can either kill it by letting out the clutch in high gear, or adjust the throttle idle down until it dies, then put a removable stop to keep it normally idling again. Yes, I've given some thought to all this).
Old 02-14-2017, 04:56 AM
So a C6 is a better tranny than a E4OD, I have a 89 7.3 with a C6 and a Gear Vendors OD. I take it that is good ?
Also I have guy here locally who is supposed to build a really mean E4OD or great Ford Auto's..... but they are PRICEY!
Fuel Pump Just Died AGAIN after 1500 miles, waiting for tow Mystic_Cobra 6.7L Power Stroke Diesel 56 09-09-2016 10:28 AM
1973 F250 Long Bed Single Cab "Build" misscali91 1973 - 1979 F-100 & Larger F-Series Trucks 38 03-01-2016 04:44 AM
Do I have one problem, or two? Instrument Cluster and 4x4 Eccles 1999 to 2016 Super Duty 2 02-19-2016 11:50 AM
Which fuse is the vacuum pump on? Need help diagnosing electrical... Studawg Excursion - King of SUVs 6 08-18-2015 07:31 PM
Fun electrical issues JPdiesel 1999 - 2003 7.3L Power Stroke Diesel 5 09-14-2011 07:01 AM
Tags
6.9, diesel, electrical, f350, idi, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
