NO electricity - Page 2 - Ford Truck Enthusiasts Forums
NO electricity
Old 02-14-2017, 01:14 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Depends on your definition of "better". C6 is SIMPLER - all mechanically controlled. Without the GVOD, it's less efficient of course. E4OD is more efficient, not just because of the OD but the ability to lock the converter. So they're "different", each with their advantages/disadvantages. Doesn't make either one "better"; that depends on the importance of each of those differences is to your needs. I sure wouldn't swap trannies just for the sake of it.
Old 02-17-2017, 08:42 AM
eraser5's Avatar
eraser5 eraser5 is offline
eraser5 is starting off with a positive reputation.
When my 86 lost all power, it was the glow plug harness dead shorting to the intake manifold. I had numerous wires that got smoked. a little FYI, if your wire has leaked out all of its smoke, it no workie no more.
Finding the short was just back tracking hot melty wires. Fun times!
Old 03-21-2017, 11:49 AM
B.Les B.Les is offline
B.Les is starting off with a positive reputation.
So I know this thread is old now, but I didnt want to start a new one unless I had to. But about 2 weeks ago, I finally found time to monkey around and try and find what was wrong with my truck. For kicks and giggles, the first thing I did was put my key in and turn it to the run position. Everything came on and I even cranked the truck. Been driving it since. But I really want to know what it is lest it happen again, because this is the second time its done this and I really cant afford a third.
Old 03-21-2017, 02:39 PM
Just going from memory; another member might have a pic -- among the main power wires coming off the power junction terminal on the starter relay, there's one big fat yellow one. A little ways down that wire from the relay it has a quick-disconnect. That's a common failure point which would basically shut down everything electrical in the truck.
Fuel Pump Just Died AGAIN after 1500 miles, waiting for tow Mystic_Cobra 6.7L Power Stroke Diesel 56 09-09-2016 10:28 AM
1973 F250 Long Bed Single Cab "Build" misscali91 1973 - 1979 F-100 & Larger F-Series Trucks 38 03-01-2016 04:44 AM
Do I have one problem, or two? Instrument Cluster and 4x4 Eccles 1999 to 2016 Super Duty 2 02-19-2016 11:50 AM
Which fuse is the vacuum pump on? Need help diagnosing electrical... Studawg Excursion - King of SUVs 6 08-18-2015 07:31 PM
Fun electrical issues JPdiesel 1999 - 2003 7.3L Power Stroke Diesel 5 09-14-2011 07:01 AM
Tags
6.9, diesel, electrical, f350, idi, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
