Programming start on integrated key
Purchased a key from ebay like the ones pictured. Long story short, after much struggle I've gotten it programmed to manually start the truck and to lock/unlock with the buttons.
I have yet to program the remote start button. The information that I've found so far says to locate the remote start system override button to begin programming it to start the truck.
I installed the Ford remote start unit myself along with the VSS (vehicle security module). I have remote start working via a cell phone app. The vehicle security appears to be working as it should.
There is no override or any other buttons on the RMST unit. Only an LED indicator light.
The ebay vendor's listing states that the key can be self programmed. So far they've been unresponsive to my questions. Everything I've done so far has been with the help of Larry (Just Strokin) or Google.
Am I overlooking something? Is there another way besides paying my dealer $50 again to hook it up to their IDS to program this key?
The RMST is NOT the cellular access module. The RMU is the cellular module. The RMST is remote start via a fob.
Did you have steps 51 to 53 in the instructions perform by a dealer? Or use FORScan to turn on Remote Start?
Just for chits and giggles, can you perform step 54 or 55 in the instructions depending on your IPC display and report back on this thread? Or post a photo?
I think ebay gives them 7 days. After that I'll open up a case.
In the meantime the other remotes from you should be here today. You've already sent me the instructions on programming those.
Also you have the scalable system up and running and functioning normally.
This means you have a hood switch, and an RFR antenna plugged into the TPMS. Otherwise if you didn't, none of the other functions would work.
So..... there's nothing left to do other than cut and program the keys. The instructions you should be following are the exact same instructions for programming a spare key. They are as follows:
- Have 2 original keys (or currently programmed keys)
- Have the new key you wish to program already cut and ready to go
- Insert the first original key into the ignition and turn to the run position
- Count 3 long Mississippi's, then remove the key
- Within 10 seconds insert the second original key and repeat
- Within 10 seconds, insert the new unprogrammed key into the ignition and turn to the run position
- Again count 3 long Mississippi's before removing the new key
Doors will lock and then unlock to confirm programming. Repeat all steps to program an additional key.
Now the issue here is you said the new keys are already programmed and will start the truck, as well as lock and unlock. This means the keys are technically programmed and the remote start function should already be working on the new keys. Have you tried on the new keys pressing lock, then double pressing the 2X button for remote start? What happens when you try that?
Ok from what I gather, you already have remote start activated on the truck, as you found the menu options in the Driver's Information Display and it is currently enabled.
I had my dealer plug it into their IDS and activate remote starting. At that time I did not yet have an integrated key, a fob, or the upgrade antenna. But I did have the TPMS antenna and the truck would remote start with the iPhone app.
I tried the procedure that you posted, several times. A message appears in the productivity screen during this procedure that says the key did not program, yet the manual start and lock/unlock functions are working on that key.
Today I received a couple of bidirectional key fobs from Larry. Had them programmed and starting the truck in seconds.
After seeing your post I went straight out to the garage and did as you said. Locked the truck with the integrated key. Hit start button 2 times. Nothing doing. Frustrating but not the end of the world.
Update: The seller has finally responded through ebay after I initiated a refund request. They requested the vehicle year/make/model and the FCC ID number of the current keys. I popped a cover off of one key and found the number and relayed it to them. Now I wait to see if they can do anything with the information. I've held off on feedback until I see how it turns out.
OK Pocket and Larry, now I'm baffled but happy. I initially went out to the garage and tried Pocket's suggestion of locking it with the integrated key and then trying to start it. As stated, nothing happened.
10 or 15 minutes later I go out, give it another shot and the truck started. Twice in a row.
Spoke too soon. Now there's nothing again. I even replaced the battery on the off chance that it shipped with a weak one.
How long do you wait in between? I went out this morning after the truck sat in the garage all night. I locked it with the fob and then tried to start. Nothing. On the second attempt it started.
I've seen old posts on the forum where guys had this hit & miss trouble, but no solutions. Oh well. At least the fobs I bought from Larry are working as they should.
However, I have 4 keys for my truck, one of them has been dropped so many times that you have to really press the buttons hard to get it to work.
Or then there's the almost non-existent range of the keys.
Glad I bought those 2 fobs from Larry. They're working just fine.
I lost one of the two OEM keys with the remote buttons on them.. What is the cheapest way to replace one that will start the truck from the inside ignition switch ?
I would keep i for a spare inside the truck in case I lost my other working key.. and needed to run the truck until replacements?.. I would love to have the spare key work like OEM with remote and door lock/unlock functions but from what I read seems to be expensive etc.
From Ford, 75 plus. Not sure about after market or chinese keys as to how well they work. you can check the price on ebay of maybe amazon. Strattec/Ford/Rotunda pn is 164-R8067.
you will need two keys to program a new key, FORScan, dealer or locksmith if you only have one key.
https://www.ebay.com/sch/i.html?_fro...R8067&_sacat=0
