Idle Question? - Ford Truck Enthusiasts Forums
Idle Question?
Old 02-09-2017, 03:48 PM
Iron Port Iron Port is offline
Iron Port is starting off with a positive reputation.
Question Idle Question?
When I start my Bronco It idles at 1200 RPM, Then surges between 1100-1000RPM and will jolt hard into reverse or drive and will want to accelerate up to 14 MPH without hitting the gas pedal. Is my idle to high and what is my Bronco supposed to idle at?
Old 02-09-2017, 07:35 PM
Bubba Jones's Avatar
Bubba Jones Bubba Jones is online now
Bubba Jones has a good reputation on FTE.Bubba Jones has a good reputation on FTE.Bubba Jones has a good reputation on FTE.
A little more information would be helpful to better help with your issue.
What year Bronco and what engine?
Have you tried checking for engine codes?
Is this idle only happening when cold or at all times?
When cold, most EFI controlled vehicles will be in 'Open Loop' mode which throws in more fuel to help bring the engine to proper operating temperature. The idle is typically higher in open loop, but it sounds as if yours is too high.
What I would first do is check for engine codes. If your truck is 1995 or older, checking the codes is incredibly easy. You just need a paperclip and need to jump two pins on the diagnostic port. It may be in a different location depending on the year of your truck, but the process is the same.
Here is a link that a user on another forum made that explains the process pretty well:
1983 Ford Bronco Diagrams picture | SuperMotors.net
If codes pop up, it would be a good thing to check those out first as the codes may be relating to your problem.
Off the top of my head, things that CAN cause high/erratic/incorrect idles are:
-Vacuum leaks
-Dirty/bad Idle Air Control Valve
-Bad Throttle Position Sensor
Usually a messed up idle isn't that big of a fix, but finding the issue can sometimes be tedious. I'm sure you'll be able to correct it though with the help of people on this forum!
High idle 1700rpm brettk1 1978 - 1996 Big Bronco 5 02-23-2017 09:46 AM
Does your truck high idle at startup? jimbo285 1987 - 1996 F150 & Larger F-Series Trucks 17 03-12-2016 04:25 PM
Selective idle MatthewC 1978 - 1996 Big Bronco 3 11-05-2004 12:52 PM
93 Bronco Idle Problem - Pls Help! girlybat 1978 - 1996 Big Bronco 12 10-31-2003 09:26 PM
Erratic Idle MJB Bronco II 6 10-22-2003 04:38 PM
Tags
idle, issue
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
