292 oil pressure
Old 02-09-2017, 07:55 AM
Danrweaver's Avatar
Danrweaver
Danrweaver is offline
292 oil pressure
I have a strange problem with the 292 in my 63 F100. When I start the engine, the oil pressure will initially jump up to about 40 psi but over the next 30 seconds will drop to zero. There is no change in the sound of the engine when it goes to zero like you would expect with no oil pressure and raising the rpms does not bring the pressure up.
Any ideas?
Thanks
Drw
Old 02-14-2017, 09:29 AM
312's Avatar
312
312 is offline
did it just start doing this.get an oil pressure gauge and hook it up and see what you have.if it really has no pressure its not long for this world.
Old 02-21-2017, 01:24 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,610 Likes on 1,454 Posts
In my 55 F350 with a 239 I have an oil pressure gauge that was added by the PO because the pressure gauge in the instrument panel did not work. The added gauge goes up to 120lbs. What should the oil pressure be in a 239?
Old 02-21-2017, 04:00 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
45-50 @2000rpm, hot
Cold pressure would be higher. However, 120 psi is excessive.
First, try a known good pressure gauge. If nothing changes, then you probably have a problem with the bypass valve. The bypass valve can be found under the screw next to the oil pickup tube in the pump.
Old 03-26-2017, 09:54 PM
Steve's Avatar
Steve
Steve is offline
Before you start it again in your diagnostic process, check the big gland nut at the pump where the inlet tube from the pan goes in. Use a big adjustable wrench and give it a half turn. There is a little barrel shaped seal back in there that expands and seals as that nut is tightened. Go easy. Half a turn should be plenty.
Old 03-26-2017, 10:08 PM
Steve's Avatar
Steve
Steve is offline
Double post.
1994_f150_mnolen
09-22-2013 04:18 PM
jlt59912
11-06-2011 11:53 AM
tony b
11-06-2006 12:31 AM
Craze
07-30-2004 04:04 AM
Quick Reply: 292 oil pressure
