Need help with correct NOS distributor # 's for 1989 F350 7.5
I need to know correct NOS distributor part numbers for my 1989 F350 w/ 7.5
The 'aftermarket' distributor that the previous owner installed many years ago is: E8TE-12127-BA
As I said, this is an aftermarket distributor and may not be correct, as I have had issues since buying the truck in 2001 that could be distributor related.
I have also been told that the correct NOS Motorcraft distributor for my truck is: E8TZ-12127-BC
Are these close enough or not compatible?
I also took pics of a small sticker on drivers side valve cover and a large emissions sticker on same cover that might help to identify correct distributor.
Usually a last letter suffix change like that indicates there is a newer version of the same part. Therefore the aftermarket part was probably a rebuilt older version.
I am not sure what issue you are chasing, but the change from -BA to -BC is most likely not your cause.
E8TE-12127 BA (current aftermarket distributor that is installed)
E8TZ-12127 BC (suggested NOS Motorcraft distributor)
I had earlier edited my original post, as caught the other difference.
That could be it, although usually they are majorly different. TBH as a Ford tech, I don't even know the difference. I leave that to the parts department even though we seem to always get the wrong part anyways.
Engineering (number on part itself) v/s Part number (for ordering in system)
"E" in the prefix denotes an Engine part.
"Z" in the prefix denotes a replacement part.
12127 = the basic part number for every distributor Ford made.
BA, BC etc are engineering revisions.
The first engineering number you listed doesn't seem aftermarket at all.
Just a part originally engineered for the fuel injected 460 when it came out in 1988.
Yogiesford
29
03-19-2018 09:10 AM
dillon1033
02-09-2003 12:52 PM
