2002 F150 XL heater/AC fan issue
Old 02-08-2017, 10:40 AM
Drwoods72's Avatar
Drwoods72
Drwoods72 is offline
Hoping you guys have seen this issue before.
My heat & AC work fine, but the only position the fan selector switch will actually blow any air is on high. Bought an OEM replacement switch and installed it but the issue still exists. Any ideas/thoughts?
Thanks
Derek
Old 02-08-2017, 11:46 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Sure do, the switch selects a lead to the speed control resistor.
The resistor has one position burned open.
On the passenger side up under the dash you will find the resistor and it's power plug on the side of the duct work.
Two screws hold it in.
Take the old one out and be sure the new one has the mounting holes you need.
Good luck.
The following users liked this post:
Old 02-08-2017, 12:22 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
looks something like this. you will see the plug end... resistors are inside the duct for cooling.
Old 02-08-2017, 02:02 PM
Drwoods72's Avatar
Drwoods72
Thanks
Apperciate the help, it has been annoying to say the least
Old 02-08-2017, 07:46 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
This issue is so common, it's in the HVAC FAQs.
nick c
1997 - 2003 F150
08-01-2016 08:32 PM
seagiant
07-19-2016 11:23 AM
mdyster
06-17-2006 07:17 AM
orangeford
08-29-2001 09:39 AM
Quick Reply: 2002 F150 XL heater/AC fan issue
