will shorty or mid length headers fit on stock?
hey, so ive got a 1989 f250 and its needed the exhaust manifolds replaced since i bought the the truck cause they're leaking. been looking at the prices for headers and exhaust manifolds and found headers cheaper. i would like to get full length but i dont have the tools or knowledge to make them fit (its a 4x4 truck) but ive read a little bit that shortys will bit no problem. was wondering if this is true and whos tried it and if mid lengths will work also?
this is the one i meant to post.
STAINLESS SHORTY HUGGER HEADER EXHAUST MANIFOLD FOR 429/460 FORD BBC BIG BLOCK | eBay
on
No they definitely won't work. I think you need a kit with a matching mid pipe like this..
https://www.summitracing.com/int/par...rd/model/f-250
I thought "they" made long tubes for 4x4...or is the big block too wide for that?
https://m.summitracing.com/parts/big-12560flt
This example fits the previous generation; is it really that much different than the 89? Maybe someone knows what is in the way and maybe it's easy to fix.
Since this is the case, and since you are going for true duals anyway, If I were you I would go for the midlength ones if it's all being done at the same time. The longer tubes seem to consistently gain the most of what a truck wants in the power band.
If you have to do it in stages, go shorty, connect it to the factory exhaust, and then when you upgrade the rest of the system you will gain the most benefit from the upgrade. I did not notice very much difference with stock exhaust on new headers in my one experience in doing this in a Catalytic Converter equipped vehicle.
