Can anyone help me identify these holes at the front of my '55 F100 frame. The section shown is being boxed in so it is just in case I need to thread them for any reason. Bear in mind the frame is upside down. Thanks.
Key Description
A Steering Box
B Bump Stop
C Bump Stop
D Brake Pipe Clip
E Brake Pipe Clip
F ?
G ?
H ?
J ?
K Shock Absorber Bracket
L Brake Hose
I know on my 54 when I took it apart...not all holes in frame were used. Left and right side mirrored each other. I would assume that some of them are where jigs were attached when frame was assembled to keep it straight.
Thanks. I know some are not used. I was particularly worried about whether the holes G and H were used for the strut going to the fender. There is also a tie onto the inner fender as well although I have no recollection of that at all and no photos.
