L96 engine - what headers??
Old 02-06-2017, 10:50 PM
KP Bob's Avatar
KP Bob
KP Bob is offline
I tried doing a search - but?
So, my question is: What headers work best in a 1956 with an LSX engine and C4 Corvette suspension(Flat Out Engineering)?
Any pics, thoughts, experience with this would be great!!
Karl
Old 02-26-2017, 10:13 PM
atvracer557's Avatar
atvracer557
atvracer557 is offline
i have a 54 with a no-limit frame and a LS3 i got with Jim at
ultimate headers jim@ultimateheaders.com
he hook me right up
Old 02-27-2017, 09:57 PM
KP Bob's Avatar
KP Bob
KP Bob is offline
Thanks for your response! I'll give him a try.
Old 02-28-2017, 07:11 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
What style header are you looking to use?
Old 03-01-2017, 12:17 PM
KP Bob's Avatar
KP Bob
KP Bob is offline
I'd like to use full length headers that come down just below the frame. My understanding is the left side is very tight with the steering and the header should hug the engine as much as possible. Stainless steel or something "pretty" would be nice.
Old 03-02-2017, 08:52 PM
atvracer557
ultimate headers is full length can do customs, stainless with a pretty flange
Old 03-03-2017, 11:26 PM
KP Bob's Avatar
KP Bob
KP Bob is offline
The ultimate headers are definitely nice, but a little more than I want to spend. Also, the full length ones don't go down low enough to clear below my frame. I will have to keep looking. The easiest would definitely be block huggers, but don't perform or look quite as nice.
Old 03-04-2017, 05:14 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
You may have to build your own, I don't think anything you find will come with a not-so-outrageous price tag. I've built a few sets of headers, it's mind numbing and tedious, but once it's done it's done.
Old 03-05-2017, 09:24 AM
atvracer557
i would have to agree with 89F2urd i was looking everywhere to fit my frame engine combo with no luck so i had to make my own or do a custom/higher end headers i don't have the time so i went with a higher end
Old 03-05-2017, 07:01 PM
Marten's Avatar
Marten
Marten is offline
I went to Sanderson Headers. Used a mid length header that was as close to the block as possible. Don't remember the number though. They were great to deal with. My truck, '53 with a 350 Chev. and the C4/Flat out kit. It will be tight for the steering though but doable.
Old 03-06-2017, 06:47 PM
Marten's Avatar
Marten
Marten is offline
So I found my bill for the headers. They are CC17 by Sanderson Street Rod Headers. They are a mid length unit.
Old 03-06-2017, 10:47 PM
KP Bob's Avatar
KP Bob
KP Bob is offline
Thanks, Marten. Looks like I'll have to go this route as well, just with the LS header instead, like the LS158 or CSLS158. You wouldn't happen to have a picture of the left side with the steering shaft in relation to the header would you?
Old 03-07-2017, 03:16 PM
Marten's Avatar
Marten
Marten is offline
Hi KP Bob
Here is a picture of the way it is today. I don't have the steering shaft in yet but do have the parts. It will take 3 u-joints to attach to the steering column. One at the column, one at the rack and pinion and one close to the frame about 6" from the rack. The wooden stick represents where the steering shaft will go. Because of the 3 u-joints you will also need a special heim joint to hold the shaft up.
Old 03-07-2017, 05:08 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Just hose clamp that wooden stick in place.
Old 03-09-2017, 07:03 PM
KP Bob's Avatar
KP Bob
KP Bob is offline
That should be plenty strong. I've been looking at the Sanderson headers and will need to contact them with better dimensions. The ones on their site aren't great.
This is approximately where I would like the steering to be. It doesn't leave a lot of room.
Quick Reply: L96 engine - what headers??
