Bronco freezes if left out overnight. - Ford Truck Enthusiasts Forums
Old 02-06-2017, 08:26 PM
Andy Mills Andy Mills is offline
Andy Mills is starting off with a positive reputation.
i have a 96 bronco 5.0 Eddie Bauer. My truck will not start. Battery is fine. Had it taken to the shop, had it back for almost 2 weeks now. She doesn't start again. She starts to fire, but doesn't turn all the way over. I need some help. I have no idea what's wrong
Old 02-07-2017, 10:58 AM
jimbo285's Avatar
jimbo285 jimbo285 is offline
jimbo285 is starting off with a positive reputation.
Check all the connections at the battery and starter. Check the grounds too. Also, was it ok when it left the shop? Maybe the alternator isn't recharging the battery and it took this long to drain the battery? Check those connections too.
Old 02-07-2017, 12:23 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
What does "battery is fine" mean? Did you have it load tested?
What does "starts to fire but doesn't turn all the way over" mean? Either it turns over or it doesn't.
What did the shop do to it to fix the problem for 2 weeks?
How many miles? Repair history? Has it done anything like this before?
Need LOTS more info to be more helpful.
Old 02-07-2017, 01:54 PM
1985 Bronco's Avatar
1985 Bronco 1985 Bronco is online now
1985 Bronco is starting off with a positive reputation.
Pull the battery, and let it sit overnight, then have it tested.
1986 F-250, 460, C6. Not running right imcqueen 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 12-31-2015 11:55 AM
1976 Highboy Tank77 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-05-2015 12:06 PM
5.0 Bronco won't crank SuperStrokin' 1987 - 1996 F150 & Larger F-Series Trucks 4 05-16-2015 02:08 PM
How much to swap manual 3 speed to automatic trans ? Aydanbilyeu New Member Introductions 0 05-15-2015 02:22 PM
Bronco VS K-5 Blazer bawrestler 1978 - 1996 Big Bronco 13 04-14-2007 08:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
