2001 F150 5.4 engine Tick/knock
Truck has 140,000 miles on it. When it's cold started it is usually quite for the first 30 seconds then developes a loud very noticeable tick. It ticks all the way till just about operating temp the it quites down. It will also cycle in and out while warming up, with the tick getting at its loudest then dropping back down to barley noticeable and working it's way back getting louder again. Any idea as to what the problem could be?
Is it more noticeable one side or the other? Is coming high or low from the engine compartment?
I don't personally think its exhaust related, but I've been wronged before lol. It sounds like it coming from the top end to me. I was originally thinking it was a lifter bleeding off, but what makes me think other wise is the fact that it doesn't instantly start ticking when I start it. It takes around 30 seconds to start doing it.
To help pin point where the noise is coming from, maybe invest in a mechanics stethoscope.
next thing is oil level and when was the last time it was replaced. i have worked on several E series vans with the 5.4 with almost the same problem and the oil level was low and they had not changed the oil in awhile which some of those engines had well over 250k miles. first thing the shop wanted us to do was change the oil and add a oil supplement like lucas or hyper lube if that did not fix the problem then we had to do some digging into the engine to see what was causing the sounds
Dukhunt22
03-08-2006 07:08 PM
