1963 Ranchero w/ a engine swap - Ford Truck Enthusiasts Forums
Old 02-04-2017, 07:15 PM
IDIoit's Avatar
IDIoit IDIoit is online now
IDIoit is gaining momentum as a positive member of FTE.IDIoit is gaining momentum as a positive member of FTE.
heres a fun little project.
63 MANchero
chassis: 89 F350 CCLB 4WD slightly trimmed.
4" spring lift
4:10's
mock up tires are 33-ish
7.3 IDI N/A block.
turbos.... TBD.
I would like to see what it takes to grenade this block
zf5
started rebuilding the floor the unibody was too wasted to repair.
Old 02-05-2017, 07:03 AM
hturner12's Avatar
hturner12 hturner12 is offline
hturner12 is gaining momentum as a positive member of FTE.
Be interesting to watch this one come together
Old 02-05-2017, 09:15 AM
IDIoit's Avatar
hope to have it running by the end of the month.
14 gauge sheet metal will be here Tuesday, by then I should have the bracing for the new floor done.
got a lightning seat to install
fuel lines, brake lines, wiring harness all on order
itll go pretty smooth, don't expect any major hiccups minus the innercooler.
but well cross that road when we come to it.
also have a RSK stuff on order.
Old 02-06-2017, 07:59 PM
IDIoit's Avatar
a slow start, but a start none the less
Old 02-07-2017, 08:54 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
will the exhaust clear the floor boards? it looks awful tight there.
Old 02-07-2017, 10:21 AM
IDIoit's Avatar
those manifolds will not be used.
ill be building a set of headers.
some of that tubing may be cut out after I start layin down the 14 gauge.
I.E. the cross over on the trans, I think im gonna radius it up a bit.
this is all there just to get a basic outline of the floor.
the drivers side is golden, but the passenger side would be pretty tight, but still can be done.
if you think that's tight, try doing headers on a 427 in a 65 falcon lol, THAT was TIGHT.
Old 02-07-2017, 12:36 PM
i ain't rite
hell headers on a 289 in a 65 falcoon is tight. with a 427 about the only way is to use fender well headers with the shock towers removed.
Old 02-07-2017, 09:57 PM
IDIoit's Avatar
yep, I had reinforced the unibody and put a straight axle under it.
admittedly, not some of my best work, but that was 10 years ago.
didn't get to work much on the chero today, got some 14 gauge,
and got the firewall outlined with box tubing.
tomorrow ill be cutting some sheet metal
Old 02-08-2017, 06:22 PM
IDIoit's Avatar
mucho betorro
Old 02-08-2017, 07:14 PM
i ain't rite
agreed looking much betterrer
Old 02-08-2017, 10:40 PM
fordtruckman838 fordtruckman838 is offline
fordtruckman838 is starting off with a positive reputation.
This ought to be an interesting build! Looking good so far!
Old 02-09-2017, 02:33 AM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
So why is the whole powertrain set so far aft? Seems like it won't be much fun come GP/injector time.
Old 02-09-2017, 07:18 AM
IDIoit's Avatar
Quote:
the nature of having an IDI in a 63 ranchero
the engine is in the proper place for the frame.
will have a removeable dog house on the inside.
also wouldn't be hard to pop the cab bolts and lift it.
Old 02-09-2017, 10:54 AM
85F350IDI's Avatar
85F350IDI 85F350IDI is offline
85F350IDI has a good reputation on FTE.85F350IDI has a good reputation on FTE.
Subbing, lookin like a pretty cool swap! My buddy has a 76 Ranchero and I'm about to force him to do this lol!
Old 02-09-2017, 10:44 PM
IDIoit's Avatar
not much to report today. cleaned up, welded some nuts into the cab mounts, and plated em in to keep debris out.
the sheet metal for the floor I decided to send to my buddy to brake the ends so it will be a cleaner install, but he couldn't do it today, I had to leave it with him.
I really need a 6' brake, I was 6" too long for the 4 footer.
its ok tho, the next couple of days im hopin back on the super duty, for a 4" lift and axle swap.
F100 Crown Vic 460 Viking Build pauli3wood 1973 - 1979 F-100 & Larger F-Series Trucks 800 Today 04:34 PM
1927 Ford roadster pickup project tacomacream 1947 and Older Ford Trucks 12 Yesterday 10:57 AM
'55 panel build sstephanuik 1948 - 1956 F1, F100 & Larger F-Series Trucks 146 02-16-2017 02:53 AM
2017 f150 lariat canopy, bedrug Native Images 2015+ F150 9 02-13-2017 08:31 AM
New ford heavy duty mud flaps ssoundwave 2017 Super Duty 109 02-11-2017 09:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
