Burnt plug on my heater/blower resistor
Old 02-04-2017, 08:12 AM
8285's Avatar
8285
8285 is offline
I've been going over my engine compartment with a fine tooth comb and I noticed a burnt plug on my heater/blower motor resistor.
Any ideas on what's wrong?
Old 02-04-2017, 08:30 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
Just a guess but I would suspect high resistance from corrosion at the male/female metal portion of the connector on the wire that is burnt......caused heat which melted the plug.
Old 02-04-2017, 09:50 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
Agreed. I would get a new pigtail for that and a new resistor. When you put it back together apply a light film of dielectric grease to the connection to keep moisture out.
Old 02-04-2017, 09:51 AM
8285's Avatar
8285
8285 is offline
Will do. Thanks!
Old 02-04-2017, 10:51 AM
brandedford's Avatar
brandedford
brandedford is offline
Just curious did this effect your heat/blower or anything else?
Old 02-04-2017, 02:51 PM
ciamcoop's Avatar
ciamcoop
ciamcoop is offline
Blower motor may not be spinning as freely as it should. That'll build up heat there also.
Old 02-04-2017, 05:19 PM
wtroger's Avatar
wtroger
wtroger is offline
Pretty common problem. The high blower speed draws a lot of current. And those spade connectors are iffy at best. High resistance in this connector for what ever reason causes heat that melts this connector..
Old 02-05-2017, 06:20 AM
8285's Avatar
8285
8285 is offline
brandedford, The blower motor still worked fine at all speeds with the burnt plug.
wtroger, Thanks for the info! Is there anything I can do to prevent the new connector from melting? I don't like the thought of melting electrical connectors under my hood!
72rtchallenger
08-09-2019 07:50 AM
MavSprint
05-08-2013 03:59 PM
nickh
02-01-2009 07:43 PM
sirkt
01-04-2007 02:04 AM
Quick Reply: Burnt plug on my heater/blower resistor
