Gas line by carb
Old 02-03-2017, 05:39 PM
86e350's Avatar
86e350
86e350 is offline
Gas line by carb
I may need to take off the short gas line in front of the carb to fix. The metal one.
What stepsndoni take ? If I unscrew the bolt or whatever is hasn't gonna spray all over the place and just keep pouring out until I fix it ?
I have a 1986 e350 460 motor.
I keep having a gas leak right there and I can only get it to tighten so much and then it's good for a long one but my commute to worknis all freeway so I feel it comes loose after time because I can't get it tightened all the way
Old 02-03-2017, 09:47 PM
Brnfree's Avatar
Brnfree
Brnfree is offline
If you have an '86 E350 with 460 and electric fuel pump then yes the gas is under pressure.
The fuel pump relay should be a little green box near your driver side front headlight. Unplug it, start vehicle and let it idle until it runs out of gas which should take around 1 to 3 minutes. Then there won't be any pressure in the fuel system.
Old 02-04-2017, 04:08 PM
86e350's Avatar
86e350
86e350 is offline
This is great thank you so much
Old 02-04-2017, 11:16 PM
vettex2's Avatar
vettex2
vettex2 is offline
Why can't you tighten it?
The gas line in the way?
Can you provide some more detail or a pic ?
pvwoodcrafts
04-23-2018 02:34 PM
jimstrecker
08-31-2007 05:48 PM
scroller bill
1978 - 1996 Big Bronco
01-16-2007 12:33 PM
TiggerF250
12-23-2004 01:16 PM
meangenejr
07-27-2004 07:52 AM
Quick Reply: Gas line by carb
