I'm back...with a 1990 Ford F-150 Regular Cab Short Box
Hey guys, some of you may remember me, some of y'all might be new, but I am back.
On Monday, I'm picking up a beautiful 1990 Ford F-150 Regular Cab Short Box (Impossible to find around here) with a 5.0L and a 4 sp W/OD manual transmission. Guy is selling it for $1200, which I feel is fair, so I told him I'll give him that much. He's done a lot of work on it and has receipts for it, like: New rear main seal
New spark plugs and spark plug wires
New brake master cylinder
New clutch master slave cylinders
New throwout bearing
New U-Joints
New stereo & speakers
New seat cover
New shifter boot
Comes with an extra set of wheels too. Do these trucks take P sized tires?
Here are some pics.
He says the only issue is a bad front U-Joint which shouldn't cost too much to fix.
Let me know what you think!
New U-Joints
New seat cover
New shifter boot
Here are some pics.
"p" means passenger, as opposed to "lt" which stands for light truck. you can use them on your truck, but dont expect them to handle the load that a truck tire will.
likewise, this truck is a different animal than what you had. i don't recall whether you are ever hauling heavy, but this truck won't handle nearly the load that your previous one would.
having said all that, a running 4x4 in decent shape, with receipts for work done, is worth every penny of the $1200 that you paid for it.
It only has one spot of rust over the rear fender, so I figured I should snap this up while it's available.
Isn't it semantics? Like, don't most people call them 4 SP with overdrive and not 5 speeds? Or is that not a thing? Would a 4speed with over drive be 1-2-3-OD?
And yes, you'll probably only find all-season tires in P series. If you want all-terrains or even more aggressaive you'll likely need to go with LTs (but they'll be load range C).
You won't find many (if any) load range E (10 ply rating) tires for a 15" rim. That starts with 16" on 3/4 tons.
And for what it's worth, the ZF6 in the '08 F-250 I had was marked "L-1-2-3-4-OD", but it was still a 6 speed.
P series tires will probably be load range B (equivalent to the old 4 ply rating). LT series will probably be load range C (equivalent to 6 ply rating). Either will work, LT will be a little tougher and handle 1/2 ton loads better. That's what likely would have come on it originally.
You won't find many (if any) load range E (10 ply rating) tires for a 15" rim. That starts with 16" on 3/4 tons.I've never heard "4 speed with overdrive" since the "5 speeds" came out (the Mazda trans in half tons was called "M5OD-R2" and the ZF was called "M5OD-HD" by Ford, for Manual 5 speed with OverDrive). I remember hearing about 4 speed overdrives back in the '80s. I'm not sure, but I think those had 4 forward gears, with 3rd being 1:1 and 4th being overdrive.
I wish mine had the I6!
The 4X4 can be used. PO says it jumps so he only uses the 4X4 when needed.
Do the oil pans on these things ever leak? He said his does. I'm assuming if that's what it is, it's as simple as buying a new oil pan and gasket?
the plot thickens ...
now it needs some sort of repair on the 4x4 and has a leaking oil pan ?
(a leaking intake manifold gasket can be mis-diagnosed as a leaking oil pan gasket; don't ask me how i know).
if i remember correctly, you are a) a student and b) doing little, if any of your own repair work ... please correct me if i am wrong, but it sounds like you may be moving from 1 money pit to another. not casting judgement here, just trying to be helpful. if i am correct on a & b, i can't help but wonder if you might not be better off with a 4cyl. ranger/s10/honda .
Repairing the oil pan leak might be as 'simple' as replacing the gasket. No need to replace the oil pan unless that is what is leaking due to pinholes from rust. Getting the pan out is the hard part. It could also be the valve cover gaskets. You really need to clean off the engine and see where is is leaking from or just start at the top and replace what is leaking first.
Don't skip on tires. They are pretty important to you and the people around you. I haul a load of firewood in my truck with P235/75R15 XL tires and the sidewalks hardly buldge from the weight.
