Gas smell - 87 Bronco
Hello, Im new to this board, seems like very good info here. I looked for this but didn't find anything about it. Own a Ranger along with a full-size Bronco. The problem is the Bronco....
87 Bronco, brand new 302, it seems that when the gas tank is anything under completely full, I get a gas smell inside while driving. Rear window is closed. Seems worse on any kind of turn I make. Worse on a right turn.
Any clue what this is? It's really annoying, and stinks...
Thanks
Thanks
Reacon it's a clue to stop smoking
I would also first check the filler tube. If not, Chock wheels and put on parking brake, keep truck running - climb under truck and take a good look at lines, around gas tank area where the sending unit is, and between tank guard and tank. Don't forget to check under the hood also - could be fumes traveling towards the back.........LOL
Dustin98SS
11-13-2002 09:30 AM
