1978 - 1996 Big Bronco
Looking for a part
Old 02-12-2017, 01:02 PM
Nate Padgett's Avatar
Nate Padgett
Nate Padgett is offline
Looking for a part
im looking for a replacement part for my engine. I have 302 EFI. Im not sure what the name of the part is but it is a metal tube that goes from the back of the left valve cover to the bottom of the upper intake manifold. Any help on what this part is called or where I could get it would be greatly appreciated. This is where is screws into on the intake
This is where it goes into on the valve cover
Old 02-12-2017, 07:25 PM
Bruners4's Avatar
Bruners4
Bruners4 is offline
Fist picture looks like an EGR valve.
Second picture looks like a valve cover with PCV valve sticking up out of it.
Two completely different systems.
Give us some additional information like year, model, engine, trans and any mods.
Old 02-13-2017, 08:42 PM
masseysbronco's Avatar
masseysbronco
masseysbronco is offline
2 different systems as mentioned above. The thing on the valve cover is the PCV valve (Positive crank case ventilation) it should connect somewhere that gets fresh filtered air I believe. The other thing is the EGR valve (exhaust gas re circulation) and it should connect somewhere on the exhaust header.
Old 02-13-2017, 08:47 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
OP listed the engine size (302), but failed to mention the year/series of the vehicle. "About Me" profile says 1986 Bronco.
Old 02-13-2017, 08:48 PM
Bubba Jones's Avatar
Bubba Jones
Bubba Jones is offline
On my truck when it had the 302, the EGR valve tube connected to the lower intake manifold, but the section it connected to was routed to the exhaust port (EGR port on cylinder heads routed to manifold, then to tube and up to EGR valve.)
I think the PCV valve just gets a large vacuum tube connected to it, but I could be wrong with that specifically.
kameronth
10-15-2016 09:25 PM
CurtSD
Modular V8 (4.6L, 5.4L)
08-26-2014 04:17 PM
Mmaxed
Modular V10 (6.8l)
03-23-2008 05:55 PM
swaynepoole
10-30-2004 01:14 PM
johns
10-23-2002 06:09 PM
Quick Reply: Looking for a part
