Non-Limited Slip or Electronic Locking
on
Where do you live? An open diff(non limited slip) makes a 2wd truck totally useless on anything but perfectly dry pavement, in the rain, on dirty or snow covered roads and anywhere offroad the truck will lose traction and get stuck way too easily.
The electric locking diff gives you the best of both worlds, when unlocked you have the greatest highway driving safety and when locked you have the greatest possible traction for low speed maneuvers on questionable surfaces.
Now personally I would never select an axle ratio that high for a pickup truck but it does depend if you're buying this to haul stuff or just to commute.
I dunno...I've had the e-locker on my '13 and my '15, and I've never had a practical use for it. The standard traction control brakes the slipping wheel, which makes the open differential function like a limited slip. Very obvious backing up my driveway...with the left side on ice you can feel the ABS pulse when the wheel slips. As the ABS is pulsing, the truck accelerates rearward.
The $470 for the option would be of more use to me than the E-locker.
Open dif isn't the same open dif that's in my '79. As Tom said, modern traction control handles a great deal of the issues by braking the spinning wheel. The numbers are just the trucks start-ability with a load. 6 speeds also have made the lower numbers more practical than in days gone by, but if you're towing often, or just want a snappier start, the 3.31 will give you a better kick.
I wouldn't say moot. Where we go hunting is all dirt/rock/gravel roads and one of the hills is a 12* incline. Couldn't make it up,in 2wd but clicked on the locker and it moved along no problem. Could I have done it in 4wd without locking, sure. But a 2wd would have had to make a run at it.
I think it goes something like this:
2WD
2WD + ELD
4 Auto
4WD + ELD
Get out and walk! Call a tow truck.
Actually, according to the 2017 shop manual in either 2WD, 4Auto or 4WD High the ELD can be engaged at speeds up to 19 mph and will automatically disengage at 25 mph and reengage when speed drops to 19 mph.
In 4WD Low it will engage at speeds up to 56 mph and disengage at 62 mph and then reengage when speed drops to 56 mph.
It also states that under "certain circumstances" the traction control system can deactivate the ELD to protect the drivetrain.
So, if you think about those numbers it would seem that it would be most useful when in 4WD Low. Of course at 60 mph in low range I imagine things are rather noisy and exciting!
2WD
2WD + ELD
4 Auto
4WD + ELD
