Rebuild or Replace Rear Axle?
I am beginning to suspect my rear axle bearings are going. Not sure. I hear a sound "wo wo wo wo" in sync with rotation speed. I guess it could be tires. Just in case, I called the dealer to ask about bearing replacement. The service manager said that they normally replace the entire rear end instead of replacing the axle and carrier bearings. Is there something I'm missing? This doesn't seem like it should be a difficult job.
Just for reference, the most complicated work I've done is replacing the rotors and front wheel bearings (hand packed!) and replacing the front and rear shocks. Other than that...nothing more complicated than changing oil or flushing coolant.
The truck is a 2002 F150 2WD open differential.
Thoughts?
-Kokomodo
Thoughts?
-Kokomodo
Rear axle rebuild is not for a beginner.. Takes time and patience.. You have to get the bearing clearance right, back lash right, bearing crunch right, and have a variety of tools. There is always a first time, but a little more experience might be in order...... Dealer can probably buy a good used unit and install cheaper due to the amount of labor involved in a rebuild.
well you can find about anything on youtube... wood drivers can leave splinters and sawdust inside... better to use brass or special tools for drivers....Driving is always a last resort.. I press the bearings onto the bevel shaft with a hydraulic press... and yes, the bottom out. ... Pinion bearing races in the case are different, you cant use a press , so a brass driver is needed.
hillcountryflt
15
09-10-2014 07:02 AM
Flathead Sarge
09-29-2012 03:30 PM
rpatrick
1997-2006 Expedition & Navigator
08-15-2009 07:23 PM
brown 4x4
09-26-2003 12:53 PM
