New Purchase Tune-Up Recomendations
Hey folks I just purchased my first diesel and I want to get some advice on what I should start looking to change soon. The truck is a 97 F250 with a little over 200k. 4x4 with a five speed. I already changed the oil and fuel filter. Any other recommendations? Thanks!
Change engine oil, trany, diffs, xfer case
Change coolant and filter if equiped
Change fuel filter and clean FPR screen in bowl
Make sure fuel pressure is at 40 PSI min in 3rd at WOT
Get this FPR spring instead of BB mod Ford Powerstroke Fuel Pressure Regulator Spring 7.3 FPR F250 F350 95, 96 Diesel | eBay
fix all intake/exhaust leaks and get an EGT Gauge
6637 mod or any S&B AIS
Turbo back exhaust or at a minimum the 3" down pipe
6.Doh trans cooler or anything better than stock
buy a scanner
https://www.amazon.com/Vgate-Bluetoo...rds=vgate+OBD2
Torque Pro
https://play.google.com/store/apps/d...g.prowl.torque
Use the communication in the profile
SAE J1850-PWM
make sure you add in Ford PIDs
https://play.google.com/store/apps/d...ch.CarGaugePro
people like it cause it will pull codes, buzz test and CCT
Some OLD PCM's have to be flashed before you can pull codes
buy a scanner
Torque Pro
SAE J1850-PWM
Clean the engine very well and start looking for leaks. Check all the fuses both under the dash and under the hood. Check bulbs behind the dash. Test heat and AC. Test parking brake. Check pedal bushings. Check all lights including 3rd brake light. Grease any steering and u joints w zerks. Test 4x4. Check connectors under the hood and tighten accessible mounts. Lots of stuff you can do without spending a dime. But when you're ready to spend money you'll get plenty of help w that here too.
Get this FPR spring instead of BB mod Ford Powerstroke Fuel Pressure Regulator Spring 7.3 FPR F250 F350 95, 96 Diesel eBay
buy a scanner
Torque Pro
SAE J1850-PWM
buy a scanner
Torque Pro
SAE J1850-PWM
20 psi when cranking
50 when running
No less than 40 at WOT in 3rd gear but use a liquid filled gauge and a grease gun hose to get it out from under hood.
knottyrope
02-03-2017 07:28 PM
Buzzard_Wing
13
06-16-2009 08:38 AM
