I have a bit of an issue one the cold side pipe as I have a eengine driven hydraulic pump where you would normally run the cold side pipe. Any ideas how to run the pipe would really be appreciated.
I'm kinda wondering if I used a belt a few inches shorter I can move the pump down with tension and squeeze the pipe over it that way. What to you think about that? How much clearance do I need on the pipes for heat?
Man I think your going to have a hard time getting an IC pipe to fit, unless you remove it.
Man aint that the truth. Im not sure this will happen. Too bad you cant invert the ic and have the exit up high..idk,what is that a wrecker or dump truck?
