What's Your Favorite Mod?
ahhh yes, how could i forget?? My dp-tuner F5 is awesome. The 7.3 PSD in stock mode can be a slow walking dog off the line (not looking to race but dame when semis beat me off the line, thats pretty sad lol). I have the 80 econ & 80 Tow tunes. Woke the beast right up and depending on what mode you are in, locks up the torque converter early. Only downside is the extra "diesel cackle" noise under load (more output from the hpop)
My 97 E250 is a hand me down from my dad.
It's a cargo van and he had the cargo area floor and up the walls about 3 inches coated with Rhino liner after replacing the factory mat a few times.
Absolutely fantastic mod.
Also love my Autpal headlights and Amazon headlight relay wire harness. LINK
I also like the canvas divider. LINK. Let's the HVAC deal with only the passenger space.
Sorry that's more than one.
I took out my metal mini blinds and curtains because I often haul several children or occasionally a load of drunk guys I take and pick up from some party they want to go to. I don't know which is worse on the interior!
Then like you I am in the south and that sun heats our vans up pretty quick...
#28
I just pulled my H4 bulbs out of my H4 conversion set-up and installed LED bulbs inside.
I also pulled the aftermarket relays out. I don't need them and they were flaky anyway.
With the H-4's and no relays I had to use a 15 amp fuse instead of the 10 amp since they pulled about 10 and 1/2 amps and blew the fuse.
This may have contributed to my alternator wearing out quicker.
So instead of pulling 110 watts I now pull 30 on low beams. Not sure how many on high but it has be lower than 120 the regular H4 bulbs were pulling. I'm guessing way under since I can't find high beam wattage specs.
Now I can use the 10 amp fuse , ditch the relays , save the alt. and have bright lights.
New bulbs:
http://www.ebay.com/itm/222599999455?rmvSB=true
H-4 conversion :
https://www.summitracing.com/parts/grm-09-124
New bulbs:
H-4 conversion :
#29
Did you do it yourself, what kind, and how much was it?
https://www.suntekfilms.com/automoti...otive-cir.aspx
#30
New bulbs:
Universal Motorcycle Bike Car H4 Hi/Lo Beam LED Front Headlight HeadLamp Bulb
H-4 conversion :
New bulbs:
H-4 conversion :
