Bad MPG!!
For that short of a commute, with 4x4 locked in at times, winter blend fuel, and those idle times.....seems reasonable actually...
these things like to be worked... we only get 18-20 to begin with.... so idle time plus those contributing circumstances...totally believable and reasonable from my end...
Winter fuel uses additives or kerosene but the Cetane Number could be lowered which causes poor MPG on a cold engine. You can use additives to bump up the CN but too high CN isn't a good thing either.
More info
https://en.wikipedia.org/wiki/Winter_diesel_fuel
https://en.wikipedia.org/wiki/Cetane_number
More info
If you are trying to calculate mpg on a single tank fill up your calculations may be wrong. You will need to fill and average several fills and mpg. Some time I can get the tanks to fill to the top and some time not so much. ( how much pump pressure, how much foam, which way the truck is tilted and some time how much time I spend getting another gal or so in the tanks) If a leak most times you will smell or see it. Take a good look in the engine valley for fuel.
Ditto...diesel doesn't evaporate like gas...
Different fuel...but in my focus I typically loose 10%-30% of my fuel mileage I go from 28-34 mpgs down to 22-28mpgs sometimes less if I Idle longer.
