Power steering pump questions
Replacing my radiator core support on my 1997 f350 soon, while I have the front end apart I'm thinking about replacing my ps pump lines which are really rusty but not leaking yet. Can I just pull those couple lines off and put new ones on? Do I need to bleed the system? If so how to? Do I need to use thread locker or any other type of sealant? Any advise appreciated never replaced them before. Thanks Kyle
Change the lines, including the metal cooler lines. Mine went with no warning; luckily I was going uphill when "Whaaaa? Where did my power assist go?" Slow down, plan for the curves, two arms to haul the wheel from side to side. Not a fun day.
Those original metal lines will be weak from metal fatigue. Mine broke off right at the pump fitting. Not something you want experience first hand.
Davehart24
01-26-2015 08:40 PM
BenS
08-30-1999 06:44 AM
