F150 - HD Truck Similarities?
How many carryover parts do the 2017 HD trucks now have that the 2015+ F150s have already. Has unitized the truck models, apart from suspensions of course, the interiors appear to be identical?
If im correct, was the only manufacturer that had 2 separate lines, the f150 and then f250/350/450's, ram and gm all used the same bodies/interiors just diff suspensions.
I'd say that it looks like the cab and everything in the cab is the same. The floor pan is probably different though.
Everything else is different, the bed, front sheet metal, bumpers, drive train and the frame.
Dodge/Ram and GM used different frames than the 1/2 ton. GM used slightly different front sheet metal.
Y2KW57
2017+ Super Duty
91
10-18-2015 09:19 AM
