Stupid question. What can cause my reverse lights not to work?
If an automatic transmission, the switch is the one on the side of the transmission that also tells the computer what position the driver has placed the shift lever.
It goes by various names. Your auto parts store will probably (incorrectly) call it a "neutral safety" switch since that's the term left voer from teh 60s and 70s. Depending on when the documentation was done, Ford might call it a DTR switch, MLPS sensor, TRS, or something similar.
What else can cause this. i did check the fuses. I really need to get this fixed its hard to see when i back up. I have tinted windows.
Thanks fir the help.
Sir, you do tread after thread about a lot of non sense and just show near complete ignorance about everything.
Any circuit starts at a fused power source, goes through control switching to the circuit destination.
What would you not understand about that?
Look for the cause of an open circuit!
We can't hold your hand and give you a kiss without being accused of being Gay..
I know this is a snarky reply but you need to get the message.
Go do the work.
Good luck.
Go do the work.
Good luck.
