Something is loose in my front end
Old 01-25-2017, 02:32 PM
joeinmn's Avatar
joeinmn
joeinmn is offline
HI, I've got an '05 4X4 sclb (7 lugger) that has developed a vibration while turning left. While on the highway even a small movement of the steering wheel brings on the vibration. I also have a lot of extra brake dust on the front right rim. I'm thinking something is worn but I'm not sure what. What do you guys think it is?
Old 01-25-2017, 04:43 PM
pdqford's Avatar
pdqford
pdqford is offline
Wheel bearing?
Old 01-25-2017, 08:23 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
jack up the front with jack under the A frame and lift tires 2 inches off the ground. stick a 4 ft 2 x 4 edge under the tire and pry up and down to see if the tire wiggles on the spindle. Rotate the tire to see if it grinds.... sometimes you have to remove the brake caliper to get a better "feel" if things are in the first stage of failure.
Old 01-26-2017, 08:20 AM
joeinmn's Avatar
joeinmn
joeinmn is offline
thanks, that sounds like a plan, I'll let you know what I find.
Old 05-19-2017, 08:55 PM
Coskid's Avatar
Coskid
Coskid is offline
Glad I poked around the site tonight because I thought I had a stuck caliper but after reading this I am almost certain it is the wheel bearings.
Old 05-20-2017, 10:25 AM
joeinmn's Avatar
joeinmn
joeinmn is offline
Ya, sorry I never updated this. It was the Hub assembly (bearings). Easy DIY project.
chrisroy1972
1997 - 2003 F150
10-23-2015 01:26 PM
FSJ-EARL
05-25-2010 01:41 PM
conman3300
12-05-2008 12:20 AM
sobsidian
1983 - 2012 Ranger & B-Series
06-13-2004 09:22 AM
176ford
04-12-2004 11:00 PM
Quick Reply: Something is loose in my front end
