Steering issues! Need Help ASAP
Old 01-25-2017, 09:28 AM
Brian Donoghue's Avatar
Brian Donoghue
Brian Donoghue is offline
I just finished my SAS on my 1997 f350. And now I am having issues about the steering. Does anyone know if I need drop pitman arm? I went threw 2 sets of new steering kits. When I turn it kinda slides and if I drive straight I have play. When I crawl underneath and lift the tires off the ground, I can turn and pay with the steering arms with thus turn the tires about 1/2". What can be wrong? When I go over bumps I don't have bump steer. My truck steering slides and I have bad play in the steering wheel from it. I also tried to tighten the gear box nut.
Old 01-25-2017, 02:26 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
Mine had lots of play and replacing the tie rods took up a lot of slop
can you take a pic of where you are pushing and seeing the movement?
Old 01-25-2017, 03:17 PM
dclack's Avatar
dclack
dclack is offline
An SAS on an F350? All 4wd F350s came with a D60. Was this a 2wd truck? I think we need more info about your truck and what you swapped.
Old 01-25-2017, 03:48 PM
knottyrope's Avatar
knottyrope
bdevr
32
02-01-2012 01:29 PM
benmoderow
03-20-2011 03:39 PM
jrandalls
01-18-2008 08:38 AM
mooncricket1
09-14-2006 08:47 PM
Pwarrenn
07-29-2005 09:18 AM
Quick Reply: Steering issues! Need Help ASAP
