2014 F250 DEF Contamination
Just got the limp mode notification about contaminated def. Could this be a sensor? Taking it to the dealer tomorrow. Truck has 40k and I am the only one that adds def.
Hopefully it is a sensor or something easy. Def contamination isn't covered under warranty is it?
The first solution for contaminated DEF is to pump out the old DEF and refill with fresh DEF. If this doesn't cure the problem, then you might need to replace the tank (probably what dealer will tell you has to be done initially).
$15 or so for a transfer pump from Harbor Freight or Wal Mart and a 2.5 gallon of DEF from Wal Mart is cheaper than a trip to dealer show it fix your problem.
Multi-Use Transfer Pump
Fury
12-14-2023 09:49 AM
doublenot7
6.7L Power Stroke Diesel
08-04-2018 12:01 PM
Slpybeartx
26
09-15-2017 03:38 PM
kcsteck
11-08-2004 06:25 PM
