6.2 thru Colorado I-70 pulling 12,000 lbs ?
So... what are some real world experiences pulling a large 5th wheel with the 6.2 thru Colorado on I-70?
I'm looking at this summer going through there, looks like 11,000 feet with some 6% and 7% grades pulling 12,000 lbs signature rig.
Gear used?
Speed?
Weight pulled?
Gear coming down and how was the engine braking?
etc...
Thanks in advance
Gear used?
Speed?
Weight pulled?
etc...
Thanks in advance
not much "Air" at 11,000 feet. Walk Slow.
no help with 6.2L or that much weight at elevation.
you will be in Second a long time. with the 3.73's
but Ford does offer the 6.2L in the F 350 Dually.
All normally aspirated engines work HARD over 8,000 feet...
take a 1 mile fast Walk over 10,000 feet.. you will understand. even if you are 25 years old.
YES, I have been there.. done that.. 12,200 feet..
I will follow this thread with great interest.
. as wife is wanting a newer/larger trailer..
I been able to find other post about gas motor homes and the V10, but nothing yet about the 6.2.
Being in aviation my whole adult life, I understand the pressure altitude and loss of performance with normally aspirated engines.
I feel good about the brake issue, since I went to disc.
I think rvpuller has made trips this high with his Dually?
When you are going into or out of Denver on 70 one of the hardest pulls or downhill grades is the Glenwood grade west of Denver. Going west we cutoff on 58 toward Glenwood and take 6 to Idaho Springs and reverse going east. Nice easy pull but it is 2 lane with a 45 mph speed limit and its a very scenic drive. The whole drive along 70 through CO is beautiful so slow down and enjoy it
Denny
Even a big rig hauling up a steep grade doesn't want to loose what little momentum they have because someone is lolly gagging.
Some have pulloffs at the top before the decent to check your brakes and let your vehicle cool off.
I pulled my 5th wheel on I-70 with my 6.2 last year. Trailer weighs right at 10500 lbs. You will be in 2nd or even 1st a lot of the time...only going 15 to 25 mph. The engine will sound like its coming apart but the high revs are normal. Coming down, the engine will help some but extra braking will be necessary. My wife wast impressed ....the reason I traded the 6.2 for the 6.7 PSD a couple months ago. Just enjoy the ride and take your time...be safe!
I'm going to take I40 thru Albuquerque, then up. Been that route before to Sedona and I10 back before but with a smaller trailer. Not as bad as going up the Rockies. Just trying to avoid the highest points.
