Why wouldn't these mirrors fit my 95 F150 standard cab? I currently have the small power mirrors but one is broke. I know I would have to drill a couple of new holes for the lower part of mount and may have to modify for top mount.
Inside are some special funny "fasteners" but if you're getting them at a junkyard just make sure to get those pieces. If you wanted to switch TO power mirrors from those pictured is where you run into then having extra holes. So, I don't see why you couldn't do what you want.
I'd think they'd fit too. Let me know if you decide to go with them because I was thinking about doing the same thing. My truck as the newer style mirrors but they aren't in good shape and I prefer this style as well. The only thing holding me back is whether the top mount holes would align with the holes that are already there.
Thanks man. I appreciate your help. The distance between the bolts on my mirror are 5 9/16". I would have to use a wide cover plate or just put a stainless bolt in to plug the hole.
Originally Posted by WestyNaut92
Looks to be about 4" bolt center to bolt center...I have a very terrible quality picture I took on my smoke break also.
