Applied power or lack thereof
NOTE I said Applied power from gitgo to beginning mid range, at that time the '17 wakes up from nap time and rolls.
I first noticed coming down the on ramp onto I 10 N. looking for the far left lane like a hooker looking for a dropped $20 bill. I've got a 35 mile drive north to make before I exit and I want to roll, my 17 dips and dodges trying to make the left lane.
I can really tell when loaded vs my '15...
I have experienced the opposite, it goes better for me. But, it has to be dry, and no dirt, or traction control starts interfering. Are you seeing full boost to the top of the gauge? If not, I think perhaps change to sport mode with a double tap of the traction button. Though I have to admit its hard to watch the gauge and the road cause it goes so hard and is so fast.
Previous gen was not torque limited. Your new truck is, plus probably a taller axle ratio and physically taller tires which serve to make the axle seem even taller.
I'm also unable to break the rear wheels free without brake torquing.
3:55 vs 3:73 plus tire size of my 20's vs dually and not sure my traction control light is lit...will check when I roll tomorrow...
on
'17 feels geared much lower, I can bust em loose, but I sure don't feel the g-forces I did in the '15. Must be all that torque, made for getting things going. Sure is comfy though!
Get the Afe torcher
From stage 3 and intake
Intuitive, On-The-Fly Controls
While the re-tweaked 6.7L Powerstroke hiding under your hood is definitely nothing to scoff at, there is always room for potential. aFe's Scorcher HD Tuner unleashes that potential by increasing turbo boost and fuel pressure, sending power levels through the roof along with fuel efficiency. Four adjustable power levels accommodate different demands, whether that means an extra boost for heavy towing or better fuel efficiency for long road trips. The sleek and low-profile assembly includes a high quality case and wire harness with factory style connectors ensuring quick and easy plug-and-play installation.
Four Distinct Power Levels
The aFe Scorcher HD Tuner Module doesn't just give you more power and better efficiency, but with four on-the-fly adjustable power levels, you can fine tune performance to suit different applications. Installation of this extremely powerful tuning system should only take around 30 minutes thanks to the plug-and-play design and OE style connectors. This powerful and versatile tuning device has been put through rigorous testing processes to ensure consistently reliable performance, and the best part is - it doesn't leave a footprint on your ECU!
Fitment: 2017 Super Duty 6.7L Powerstroke
Power Increase: up to +50HP & +85 lbs/ft TQ
Exactly. But even though the dually had the shorter axle ratio, made even better by the short tires, it still had to turn two sets of tires. I'd say the biggest limiting factor is the torque management system.
